Pentax Optio 60 Digital Camera Logo
Posted on Feb 26, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Pentax Optio 60
What is the largest SD Memory card you can put into this model?
Anonymous
Level 3:
President:
  • Master 423 Answers
  • Posted on Mar 20, 2009
Anonymous
Master
Level 3:
President:
Answers
423
Questions
Helped
160535
Points
1338
Largest card for the Optio 60 is 2GB. The camera is not able to take 4GB and larger SDHC type cards. If I answered the question to your satisfaction, don't forget to rate it. Thanks
2helpful
Pentax Optio M30- How do I transfer pictures from the internal memory onto an SD card??
this model not support it, To do that, you need to connect to pc and transfer it. As long you inserted the SD card, IT will use memory from SD card and not display image, video from built in memory.
if you want to delete file in built in memory, you need to remove memory card.
check this :
PENTAX OPTIO M30
I have a pentax Optio E10 camera and put a 4gb sdhc memory card in but it doesnt respond when I switch it on - does this mean it is not compatible or is there a way of sorting the problem
The manual specifies SD cards up to 1GB. Cards bigger than 2GB are actually SDHC (SD High Capacity) cards and will not work in SD devices. 2GB cards may work; try at your risk.
My Pentax Optio S5z does not store images to SD
Copy your photos to the SD card in the camera. http://www.pentaximaging.com/files/manual/OptioS5z_web.pdf p. 136
Transfer all photos to your computer from your SD card, and then put the card back into your camera. Try looking through your manual to see if there are any other settings that are required in order to save photos to the memory card.
1helpful
My card is locked. what shall I do pentax optio
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Sdhc memorty card in a pentax optio e10 camera
The E10 works with SD cards. While SDHC cards will fit into the slot, they are electronically incompatible and will not work. You need to use SD cards 2GB and smaller.
2answers
Largest capacity SD card for Pentax Optio S5N
The maximum supported size is most likely 2GB SD Card. Cards with 4GB and more are following a new (incompatible) standard called SDHC (SD High Capacity), SDHC cards work only in devices specifically supporting SDHC. The Optio S5N uses the old SD standard where 2GB are the maximum size.
Top Pentax Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Rob Hill
Rob Hill
Are you a Pentax Camera Expert? Answer questions, earn points and help others
