Pride Mobility Products Jazzy 1170 XL Plus Logo
Posted on Mar 16, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Need details on changing batteries on my zazzy 1170xl
Tigre Noir
Level 2:
Sergeant:
  • Expert 317 Answers
  • Posted on Jun 15, 2013
Tigre Noir
Expert
Level 2:
Sergeant:
Answers
317
Questions
0
Helped
143192
Points
700
2answers
Wireing diagram for a Zazzy 1100
I recently tried the DIY service and repair manuals from a website and it actually helped me repair transmission problem in my jcb 3cx site-master.
It would'nt move forward or reverse, engine was good both solenoids for forward and reverse worked, but still couldn't diagnose the problem.
I don't have much technical knowledge but I just followed it step-wise, and now it works perfect! covers wiring, codes, diagrams, torque specs, PCV, everything
got it from www.reliable-store.com
I know my batteries need changing. How can I change them. And are recharable batteries OK to use?
Batteries to be used in what make and model of camera ? The manual should give you details of the kind of batteries that can be used.
Dec 04, 2017 • Cameras
1170XL Plus Pride wheel chair problems, VSI shows full charge, and gets hot after a few hours
Medicare should be able to help you locate a service center. The controller has some electronics that may have been damaged by the rain. It needs to be tested for sure.
Motor Brushes are wedged in..
hi, well with extreme care you can pick away at the brush using a very small screwdriver however you must be careful that you don't damage the commutator on the motor, pick away from the corners in wards keep checking that you haven't hit the motor, extreme care is required here,, please note the brush is made of carbon so will break up...
Regards
Rob
www.gewizrepairs.co.uk
1helpful
Tire 1170xl
if i remember correctly there should be a single nut holding that tire on,use a rubber hammer and hit drive shaft and pull on tire at same time with other hand,it should move out far enough to get a large wrench behind the tire and push toward chair untill tire comes off
My jazzy 1170xl plus won't move. When I power it on the lights come on like there supposed to but as soon as I move the joystick the battery level lights start to flash rapidly. 9 of the 10 lights...
Code 9: brake fault. Check motor connections and make sure that the levers are in the engaged position - if you can roll the chair the gearbox is not engaged.
How to change a battery in a samsung np530u3c The battery of my note book is dead so, I need to change that so i need to know where is locate, thank you
They are usually located in the rear bottom of the laptop. Typically with 1 or 2 clips that you will have to slide or unlock to remove it.
Remote panel not working after changing batteries.
you will need to reset the house code. it should be listed in the owners manual on how to do this.
Top Pride Mobility Products Health & Beauty Experts
Rob Hill
Rob Hill
Grand Canyon Tech
Grand Canyon Tech
Sean Wright
Sean Wright
Are you a Pride Mobility Products Health and Beauty Expert? Answer questions, earn points and help others
