How do you change fork oil for 1999 Harley fxdwg
Hi, Anonymous for this scenario you will need your service manual that has all fastener torque specs -fluid capacities and a wiring diagram on the back pages, parts fiche, and owners manual if you can not find the best tool you ever bought for your Harley, despair not, for a mere zero $0 you can download another one.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below and for more specific information or questions at no charge please feel free to contact me at [email protected]. Good luck and have a wonderful day.
https://www.hdforums.com/forum/dyna-glide-models/504733-dyna-front-fork-oil-change-procedure.html
https://www.mediafire.com/file/zclmtnmvjmvx3ff/1999_Harley_Dyna_Service_Manual_%25281%2529.pdf/file
https://partsfinder.onlinemicrofiche.com/ronnies/showmodel.asp?make=hdmc
https://serviceinfo.harley-davidson.com/sip/service/document/6300
https://www.6ya.com/ to speak to me personally
SOURCE: Front fork oil capacity
Hi Lukepentcof.
its 350cc or 11.8 ounces in the Clyma book, but that's for a 1986 onwards model. you can vary the amount you use to suit your style of riding anyways. I doubt it would be that far from the mark.
regards
robotek
SOURCE: how to replace fork dust and oil seals on a kx125
i would do the same as the other post has said, but i would use the old seal to drive the new seal in with a rubber mallet that way you cant damage the fork.
SOURCE: will a gas tank off a 5 harley dyna wide glide
It sure will!! You answered your own question. guess i get no points for this one.
SOURCE: How do I change the fork oil on a 2002 Heritage
look at the fork legs at the bottom there is a bolt on both legs its only a small bolt,,, undo this bolt and the fork oil will drain out,, to refill the forks take the top nut off the fork leg near the handel bars,,,,,,dont over fill with oil,,,and only use the proper oil,,or the seals will blow out and the forks will be very stiff
SOURCE: How much fork oil do I put in my gsxr 600 ,1999?
if you go to CARL SALTERS MANUALS you will be able too down load all the service manuals for the GSXR600 1999 for free and it will give you exact messurements plus diagrams it has absolutely everything that you will ever need or want to know wish you the best with your bike have a 750 gixxer myself what a machine take care bud
