Master
- Posted on Mar 14, 2013
Re: waterway model # pf-50-2n22c
The wet end of pumps come off this way.
- Remove the face plate of the pump.
- Put a large flat-head screw driver on the back of the motor on the shaft going thru the motor.
- Grasp the impeller (with the screw driver in place on the back of the motor) and unthread the impeller counter clockwise.
- If it doesn't unthread you will need to bust it off
- On the back of the motor you will find 4 small bolts 1/4" size that run all the way through the motor and thread into the four fingers of the wet end.
- Unthread those 4 bolts and you can then remove the volute from the motor.
Rod
US Parts Center
888-521-6183
