HP PSC 2175 All-In-One InkJet Printer Logo
Posted on Feb 22, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Align cartridges My Hp psc 2175 all in one printer keeps saying align cartridges but everytime i do it only does 2 black lines and it won't stop asking and i need to scan some documents but it won't let me. How do I fix this???
  • angelaaton Feb 23, 2009
  • leslvart May 14, 2009
    When I plug in the printer is says, "Press Enter to align cartridges". I do that and it says"printing align cartridges page". It starts printing and a few seconds later says that it failed and spits out a page with a longer solid black line and a shorter solid black line underneath the first line.
rumorbill
Level 3:
Renaissance:
An user who is expert in 3 categories / brands.
  • HP Master 544 Answers
  • Posted on Feb 22, 2009
rumorbill
HP Master
Level 3:
Renaissance:
Answers
544
Questions
0
Helped
144413
Points
1569
You could try to get out of this mode
Press & hold SETUP than press COPY OPTIONS
After changing ink carteidge it keep saying align cartridge, what can i do to erase this error?
It is my pleasure to guide you.
These steps will take you through the process of replacement and alignment.
1. Turn on the unit, then open the print-carriage access door by lifting the
handle until the door locks into place. The print carriage moves to the center of the unit.
2. After the carriage stops moving, lift the latch to release the print cartridge, then pull it toward you out of its slot.
3. If you are removing the black print cartridge in order to install the photo print cartridge, store it in the print cartridge protector.
4. Remove the new print cartridge from its packaging and, being careful to touch only the black plastic, gently remove the plastic tape.
Caution! Do not touch the copper contacts or ink nozzles.
5. Push the new print cartridge into the appropriate slot until it clicks into place. The tri-color print cartridge goes on the left and the black or photo print cartridge goes on the right.
6. Pull the end of the latch toward you, press down until it stops, and then release. Make sure the latch catches below the bottom tabs.
7. Close the print-carriage access door.
align the print cartridges
The HP PSC prompts you to align cartridges every time you install or replace a print cartridge.
Aligning the cartridges ensures high-quality output.
To align the print cartridges when prompted:
1. Press Enter on the front panel. A page of patterns is printed. The cartridges are aligned correctly. Recycle or discard the page.
To align the cartridges at any other time:
1. Press Setup.
2. Press 2, then press 2.
This selects Maintenance, and then selects Align Print Cartridges.
I found the manual for this printer, if you do not have it already. If you wish to download it click or copy this link
http://h10032.www1.hp.com/ctg/Manual/bpu73527.pdf
Good luck and please post back that you are successful and give thumbs up if my solution has worked for you. If I can be more helpful just reply.
My HP psc 2175 keeps saying to align paper after I put in a new black cartridge. I have aligned it 5 times and the message still will not go away. The cartridge is a new HP.
what about the color cartridge? try replaceing that as well and do a power cycle of the unit/power drain on the printer before retrying the alignment process
Can't print in black ink.
Wipe the cartridge of cotton,don't use water.Make sure the black is not empty.
My hp psc 2175 all-in-one keeps giving me the message "press enter to align cartridges." When I do that it says" printing align cartrigdes page" then it says "alignment cancelled" and then goes back t
Hello Dear; When you install new cartridge the machine going to alignment it is neccessary you just follow the direction step by step to finished the procedure.
21helpful
HP 2175 Printer won't align new ink cartridges.
press 'setup' and 'options' buttons at same time to overide
2answers
How to install the print cartridge on the hp psc 2175
I found this site where you can see exactly how to access and change your printer cartriges.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpu05206&lc=en&dlc=en&cc=us&rule=22474&product=90809
Hope this helps. Bud
The printer can not align cartridges.
Try holding down the setup button, then hitting the options button at the same time. This worked on my hp 2175. Might work for you!
1helpful
Hp psc 2175 all in one printer keeps giving me a paper mismatch message.
Hello tabbeach. The printing cartridge align page message appears if u have any alignment job pending, if it asks to print the alignment page. Follow the steps provided here.
Still if u are facing the same issue, perform a HP Media sense caliberation , which in most cases will resolve the issue
the steps to perform media sense calibration are provided here .
gud luck
Aligning new cartridge
I had the same problem and did some searching on the HP support site (what a mess...)
I did find there was a new firmware update for the 2175. I tried it, and it worked for me. The note on the update says that there were problems.
Here's the link:
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=oj-14037-3&lc=en&cc=us&dlc=en&os=228&product=90809
k24674
Grand Canyon Tech
Grand Canyon Tech
