Replacing the clutch/brake levers
Hi, Anonymous for this scenario you will need your service manual that has all fastener torque specs -fluid capacities and a wiring diagram on the back pages, parts fiche, and owners manual if you can not find the best tool you ever bought for your Honda, despair not, for a mere zero $0 you can download another one.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
https://www.youtube.com/watch?v=AElEQmOBNLk
http://www.mediafire.com/file/65o6mbkdq5ty8ke/99_to_05_Harley_Softail_Service_Manual.pdf/file
https://partsfinder.onlinemicrofiche.com/ronnies/showmodel.asp?make=hdmc
https://ownersmanuals2.com/harley-davidson/softail-deuce-2005-owners-manual-66406
https://www.6ya.com/
SOURCE: replace handle bars on a 2006 HarleyDavidson RoadKing
I added a 2 inch riser to my dyna and didnt have to replace any cables, so - to answer your question, not always. There is plenty of wiggle room, however, if there is gonna be more difference that about 2 inches, replacement will be required. ADJUSTMENT WILL DEFINITELY be needed. And no, its not difficult, when u have the bars off, its nearly 1/2 done anyway
SOURCE: Front braking is lost after changing lever.
the abs module needs to be bled via the hd digital technician 2 software; sorry need to take it to a dealer; can't fully bleed the module w/o it and it may interfere w/ warranty issues later
SOURCE: How do you replace the brake lever on a Harley
There is a snap ring on the bottom of the post that holds the lever in. Use snap ring pliers to remove the snap ring, remove post disconnect the lever from the cable.
SOURCE: How to adjust front brake lever on '06 hd road king?
This is by design. When you have new pads on the bike and a rotor within limits the lever has very limited travel before engaging.
As these parts wear the position of which the lever engages changes. Unless you know that at the last brake pad change the caliper was "centered" this could account for the travel and will result in premature wear on the components.
JP
SOURCE: my brake lever gets stuck and brake light does
spray lithium grease on switch button and make sure housing for throttle and switches are as tight to brake handle clamp as possible. Also if there is the mechanical lever in brake clamp the "paddle" may need to be bent a little
