Samsung RF217ACPN - 20 cu. ft. French Door Refrigerator Logo
GENE BOWMAN Posted on Mar 03, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
BLINKING light display on refrigerator
Blinking light display and no interior light are on
Anonymous
Level 3:
  • Master 551 Answers
  • Posted on Mar 26, 2013
Anonymous
Master
Level 3:
Answers
551
Questions
0
Helped
105428
Points
1063
Your internal light may be fused otherwise connecting wires are get damaged.
Kenmore upright freezer has blinking interior light and beeping at control panel. Showing a blinking C and then a 1 on the panel.
For bottom freezer 111 models:
The control detects low refrigerant charge or a defective compressor. A refrigerator service technician will need to complete this repair because it involves the recovery and recharge of refrigerant (Freon).
How to reset a samsung refrigerator model number rs261mdpn aftthea power outage
http://www.searspartsdirect.com/partsdirect/part-number/Samsung-Parts/Refrigerator-Parts/DA41-00669A/0046/401/Model-RS261MDPNXAA/1482/0165000
this is the control board you will need for your model if unplugging the unit for 5 minutes doesn't fix the problem. If they are LED lights, then I point my finger at this. This is a plug and play board with molex connectors. Very easy to install with unit unplugged. You can manually reset the display and check for error codes by holding the top left and top right button on your user interface for 5 seconds in unison FOR 5 or more seconds after all the lights flash.
3helpful
2answers
How do I reset blinking code, 33 E, on Samsung French door fridge after power outage?
33 E code, hold energy saver button and the lighting button at the same time for 6 to 10 seconds
Not cooling and led blinking from top to bottom
Your refrigerator is in "Cooling Off" mode, or sometimes called "Store Display Mode", which basically allows everything in the fridge to function except for the Cooling system. Press and hold down the "Lighting" and "Freezer" buttons for 5 seconds until you hear the "Ding Ding". Your 'fridge will be working again.
25328782800 freezer not freezing 2 lites blinking
The problem your refrigerator has sounds like a 297370602 Main Control Board
Can you unplug refrigerator and go into the control panel inside the fresh food section? Examine the board for burn marks and swollen capacitors. I will be here if you have questions, Sea Breeze
Liebherr wine cooler lights blinking
hello the light temperature of my leiberr wine cooler is blinking and the temperature indicates an increase in the internal temperature how to fix it?
In my freezer, there is a blinking red light next to the icemaker on-off switch. What is it and why is it blinking?
It might be blinking because it hasn't been able to reach the required temperature or the temperature you have set. Probably leaving it close for one or two days, the light will go off, if not, you might consider changing the plastic isolation of the door, you know, the plastic thing that you see goes around the freezer door, best luck.
Jul 26, 2012 • Freezers
BLINKING dE(DEFROST) LIGHT ON OUTSIDE DOOR PANEL OF GE TFX27FH.
look for the manual its usually underneath...remove the grille and look inside. sometimes its taped up
i can help you troubleshoot if you find!
Oct 08, 2009 • Freezers
Top Samsung Freezers Experts
Jay Finke
Jay Finke
Arnie Burke
Arnie Burke
Are you a Samsung Freezer Expert? Answer questions, earn points and help others
