Question about Samsung RF323TEDBSR 31.6 cu. ft. French Door Refrigerator in
Showing code 8E - Samsung RF323TEDBSR 31.6 cu. ft. French Door Refrigerator in
Posted by Romaine Ragland on
Jason Reaves
    New Friend:
  • 49 Answers
This error code means the ice maker sensor is bad. On Samsung the sensor is part of the actual ice maker which you can find here.
Ice Maker For Samsung Refrigerator Model RF323TEDBSR
Posted on Sep 28, 2015
  • michelle marbach
    michelle marbach Oct 28, 2015
    That's funny because neither one of the ice makers have worked for a year. They stopped working right after the warranty was up. :)
What does error codes 8E and 26 E mean
You have a defective sensor or the main board is defective. Will take a service call
Oct 28, 2015 | Samsung RF323TE 31.6 cu. ft. French Door...
My kenmore upright freezer has a digital display that shows alarms. it is showing a ff and a ce code. can you tell me what they mean?
You have a bad freezer fan and need to replace it. The fan is located behind the back wall INSIDE the freezer. The unit will warm up a little because the air wont circulate the way it is supposed to. You can try unplugging fridge for 30 seconds to reset the control board u can do it yourself although I don't recommend it because u need actual diagnosis but this seems it hope it helps try buying part from sears or amazon
Dec 10, 2013 | Kenmore Freezers
My Miele F 1411 Vi Freezer is showing error codes _F 01 21. What do they mean?
I believe this is a code for electrical circuit. Not sure, but get it looked at this is some that is leading to something serious.
Feb 01, 2013 | Miele Freezers
P-1 code is flashing on temperature display
P1 is almost always a fault on the sensing (control) probe. Check it's end is not wet or covered in thick ice, and check the connections at the controller. If you can, change the probe connections on the controller temporarily. If P2 then shows it proves the probe is faulty. If P1 still shows, it proves the controller is at fault.
Apr 20, 2012 | True 72 cu. ft. / 2039 liter Commercial...
Temperature control show code CE model GLFU2067FW4
It means there is a wiring error in the door. The only way to fix this error is to get a new door. What a pain! I had the same problem and the freezer was only 1 1/2 years old - thank goodness the manufacturer didn't charge me.
Mar 28, 2009 | Frigidaire Freezers
Aeg fault codes
aeg santo fridge/ freezer
The fridge part of my appliance is not getting cold please help
Apr 13, 2008 | AEG 10.35 cu. ft. / 293 liter Upright...
Samsung RF323TEDBSR 31.6 cu. ft. French Door Refrigerator in Logo
1,612 people viewed this question
Top Samsung Freezers Experts
Tad
Level 1 Expert
Harrie
Are you a Samsung Freezer Expert? Answer questions, earn points and help others
