In Windows Media Player, click
Library and then, in the List pane, click
<List Name> List, and then click
Burn List, as shown in the following screen shot.
If you need to clear the list before beginning, click Burn List, and then click Clear List.
- Drag a folder from the Contents pane or songs from the Details pane to the List pane to create a list of songs to burn.
- In the burn list, drag songs up or down to arrange them in the order you want them to appear on the CD.
- Insert a blank CD-R or CD-RW disc in the CD drive.
In
the List pane, verify that the songs you have selected to burn will all
fit on the disc. If necessary, remove songs from the list by
right-clicking a song and then clicking Remove from List, as shown in the following screen shot.
It is possible that a song will not
fit even if the total time exactly matches the CD length, because the
Player inserts two seconds between songs when burning.
Click the
Start Burn arrow and verify that
Audio CD is selected, as shown in the following screen shot.
lick
Start Burn.As the CD is burned, you can check its progress in the burn list. Burning a CD will take some time.
Notes It
is recommended that you do not try to perform any other actions while
burning a CD. For example, playback may be affected if you try to play
a music CD while burning a CD.
You
cannot burn additional files to a CD after burning is completed. If you
are using a CD-RW, you can erase the entire CD before using the Player
to burn files to the CD again.
