WHICH MEMORY USE THIS BOARD
Hello here are the info about the mainboard:
http://www.asus.com/Motherboard/M2VMX_SE/#specifications
The mainboard uses:
2 x DIMM, Max. 4 GB, DDR2 ram.
The driver download site:
http://support.asus.com/Download.aspx?SLanguage=en&m=M2V-MX%20SE&p=1&s=24
Good luck
SOURCE: m2n-mx se plus with amd64 5200 automatic shut down
it might be a bios problem. Check that your harddrive and cdrom are set correctly too. For example if your harddrive is set to master and your cdrom is set to slave, change the cdrom to master and harddrive to slave and see if this helps.
SOURCE: REQURE MANUAL FOR ASUS P5VD2-MX SE MOTHERBOARD
I hope this is the manual that you're looking for.
please download it here. http://www.manualnguide.com/dl/9352/
SOURCE: vga driver of m2v-mx se
Windows XP VGA driver - http://dlsvr04.asus.com/pub/ASUS/misc/vga/VIAS3G_VGA_V6141071.zip
Vista Driver - http://dlsvr04.asus.com/pub/ASUS/misc/vga/VIAChrome9_VGA_V7141060_vista32.zip
SOURCE: i lost the driver of my motherboard driver M2N-MX SE PLUS
Click on the link below and fill in the questions
Go to www.filehippo.com and get a copy of Free Download Manager, install it before you go to this site to get the software
http://support.asus.com/default.aspx?SLanguage=en-us
That way if the download fails it will automatically handle the restart for you
SOURCE: Asus M2N-MX se plus board.... compatible with GF
maybe it is an AGP slot, there is also a pci-e slot.
