Although all the buttons are working fine but there is no connection between the two sets. when i press the transmit call tone button there i don't receive the tone on the other. please help ?
No, the battery will not have an effect on whether the two radios talk to one another, unless the battery is bad or dead.
Check your programming to be certain your Frequency, Interference Eliminator Code, and Qt Filter if any are set the same between the two radios. For basic operation shut off the Code and Filter (set to zero).
Yes, the two radios, if both produced for use in the USA, will work together. You will need to see the frequency, code, and Qt filter, if any, to the same settings as one another. For ease of use, set the code and Qt filter to off (zero) for basic communications. Then you will only be choosing a number for your frequency. Here are the user guides for each:
The T5920 is user programmable. It appears your VX6R does not have a CODE turned on, if you can receive transmissions from the T5920, but not talke back. The T5920 has both a CODE and a Qt filter. The Qt filter must be set to zero to communicate with other brands of radios. And to turn off your CODE, you will need to set it to zero also. Here is a link to the user manual: http://www.giantintl.com/ContentManage/manuals/Moto/T59xx_User_Manual_E.pdf
Set both the frequency and the interference eliminator code to match one another. (The big number and the small number) Here is a link to the owners manual: http://www.motorola.com/mdirect/manuals/T56XX_57XX_User%20_Manual_E.pdf
Basic instructions:
Press the Menu Button
The freq number will flash
Use the + or - button to select the frequency.
Press the PTT button to save the channel setting.
To set the code:
Press the menu button until the code starts to flash (the small number)
Press the + or - to select the code.
Press the PTT to save the code setting.
Once you have both radios matching on frequency and code, they should communicate together.
1.Press and hold the Multifunction button in the middle of a boom headset while the headset is closed. The light will glow blue.2.Open the boom microphone and the blue light should remain on. If not, repeat step 1. 3.On the cell phone, press Menu > Settings > Connection > Bluetooth > Handsfree > New Device 4.Select H700 once a connection is detected. 5.The passkey "0000" is now entered to confirm the connection has been made. 6.The cell phone screen will now read "Bluetooth Connection".
Tips: 1.Provided you set the Bluetooth power to "On" after the initial connection has been made, the phone will automatically re-connect to the headset. 2.To set the Bluetooth power on - Press Menu, Select Settings, then Connections, then Bluetooth link, scroll to Setup and select that. Scroll to Power and chose Change. Scroll to On and press Select. The screen should now read "Changed: Power On". 3.Test Your Connection: Close the headset and watch for cell phone to say "Disconnected". Re-open the headset and the phone should be connected automatically and will now display "Bluetooth Connected".
please give good rating if the solution works. Thanks for using FixYa.
1.Press and hold the Multifunction button in the middle of a boom headset while the headset is closed. The light will glow blue. 2.Open the boom microphone and the blue light should remain on. If not, repeat step 1. 3.On the cell phone, press Menu > Settings > Connection > Bluetooth > Handsfree > New Device 4.Select H500once a connection is detected. 5.The passkey "0000" is now entered to confirm the connection has been made. 6.The cell phone screen will now read "Bluetooth Connection".
where you have connected the wireless keyboard, probably it's a small stick coming from your computer or a cable to an infrared reciever, it probably has a little button
