MASTER CODE IS NOT WORKING WHICH IS GIVEN BY YOUR COMMUNITY
HI CAN U HELP ME TO UNLOCK MY NOKIA 1600 I DONT REMEMBER THE PASSWCODE THE IMEI 358073014472034,MASTER CODE WAS GIVEN BY YOUR COMMUNITY BUT IT'S NOT WORKING... PLEASE HELP ME
Hi, You can use Master rest codes and completely reset your Nokia 1600, thereby removing the security lock. Get the Master reset codes from Unlock-free.com for free of cost!! Hope this helps you!!
You can use Master reset code to unlock your Nokia 1600, that is what i did when i forgot my security code. Try Unlock-free.com , they provide Master reset codes for free of cost.
Hi, - To unlock you Nokia 1209 (if forgot or lost lock code) you can unlock it using a master code. - To get the master code i need the IMEI code of your mobile phone. - With the help of this IMEI code we can get the master code of your mobile and unlock the mobile and reset it with a new password. - The IMEI number can usually be found on the sticker underneath the battery or by typing *#06# into the phone keypad.
Hope this helps, please rate and leave a comment if the solution was helpful, thanks!
To unlock your nokia 1600,here is a code to unlock mobile,i have given the default service operator,
#pw+6532833265+n#
n:1 or 2 depending on what you entered
ok...since you've provided your IMEI number, there's a mastercode for your phone, which I've calculated, when you're asked for the security code on your phone, please enter this code instead: 2757023532 remember that the code might not work, but it is well worth a try.
hi, i can give you the master code but you need to read this first ok. 1. the master code wont work if you have entered 5 wrong codes as the phone will be hard locked and can only be unlocked using flash lead and unlocking software. 2 the code only works if the phone asks for security code when first swtched on.
If you have not entered 5 wrong codes then this master code will reset the security code and remove it unless you want to put another security code back on the phone. enter this code when asked for security code ok 4365426660.
This code will only work with your imei number as every single phone has a unique master code based on the imei number ok so double check the imei number before trying the code. Any problems just give me a shout back ok.
I need the IMEI (International Mobile Equipment Identity) number. Type this code in your phone to get it: *#06# you can also find it beneath the battery. Then I’ll give you the Master code to reset your Security code.
