I cannot connect to the internet using dial up connection.I tried uninstalling/installing the modem, tried querying the modem and its working fine.I tried to connect using the same isp but using another laptop and it was able to connect. Is there anything more that I need to check? Please help me out. Thanks.
First load the mobile softwares on your PC from the CD
Once the necessary softwares are installed connect your phone through data cable
then follow below given procedure
Go to Start > Settings>control panel> double click on phone & modem
New pop up window opens.in this window got to Modems tab and select the phone modem which would be visible there.
click on the properties and then on diagnostics
click on query modem in new window and wait for some time to get response
You should see that AT command SUCCESS in the command response text area. If doesnt get any response check your phone or contact your phone manufacturer.
Now got to advanced tab in same window and put extra initialization commands given below:
AT+CGDCONT=1, "IP", "aircelgprs"
Now Modem installation complete
Create Dial up connection for Aircel:
Go to My Network Places ,click on it
click on View Network connections
go to create new connection
select connect to internet
select "Set up connection manually"
select connect using Dial up
select mobile handset Modem
Click next and put ISP name as Aircel
?· In next window put *99***1# as dial number
Leave The User Name, Password and Domain Fields Blank and select make this default connection & shortcut to desktop and click Finish.
Now you can connect through dial up.
