Hi Jeff, As you can see there's 3 different Bosh washing machine models, Hope you can find your error code.... CHEERS..
F16 - Door lock error
F17 - Inlet valve error detected
F18 - Drain error detected
F23 - Anti flood device has been activated
F34 - Door lock error
F42 - Motor fault
F43 - Motor fault
F44 - Motor fault
F16 - Door lock problem
F17 - Inlet valve
F18 - Drain pump
F21 - Motor
F23 - Anti flood system activated
F01 - Water intake timeout
F02 - Heating timeout
F03 - Draining timeout
F04 - Motor fault
F05 - Uncontrolled motor startup
F06 - Short on NTC Detected on hot water intake
F07 - Open circuit NTC Open circuit wiring
F08 - Door open when program started
F09 - Unexpected heating
F10 - Communication error
F11 - Overheating
F12 - Short circuit
F13 - Mains voltage too high
F14 - Mains voltage too low
F15 - Faulty temperature sensor on motor PCB
F16 - Faulty rinse sensor Displayed only in test
Error 41 and door not locking. Tech came today and said that the hinges needed to be replaced as they weren't allowing the door to close properly. This on a 10 month old dual fuel Bosch.
I tried to use the self-cleaning feature on my (gas) Bosch HGS7282UC range, and it started beeping, with "ERROR 41" showing on the display, as well as a lock symbol. The door can be opened, so I think that the inability to lock the door is the cause of the fault - which can be traced back to the doorknob of a gas-fitter who removed the door for no apparent reason when hooking up the gas to the stove.
LOCK SYMBOL WON'T COME OFF. CAN'T BAKE.
