No power Wow, problem solver... 10hp 5000w coleman,used 4times, 3gal of gas, monkeyed around to power up my furnace,forgot to turn off hydro from the pole , what did i fu-k up.. Hector thanks
Check that engine speed is where it needs to be (does it sound like it is turning too slow or too fast?).
Pull the end cover off alternator, you should be able to see the diodes for the field winding. Check the diode with a multimeter. I bet that you will find that it is defective. Also check continuity of the field winding, both wire to wire, as well as each wire to the core of the rotor. Take a look at the brushes as well for severe wear.
Oh, if the diode is blown, plan on replacing the capacitor as well.
