Compaq Presario 2190US Notebook Logo
Posted on Feb 08, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
No wired or wireless connection
My compaq presario 25oo will not connect to the internet. I click on internet explorer and it will just say working offline NO MATTER WHAT I TRY TO DO HAS MODEM GONE BAD ? once before this happened took to a friend of mine did something and was okay for couple months BUT cannot get in touch with him to discuss. Laptop in great shape hate to get rid of it because I cannot get on line HELP !!
DEKR
Level 3:
Genius:
  • Compaq Master 1,102 Answers
  • Posted on Feb 08, 2009
DEKR
Compaq Master
Level 3:
Genius:
Answers
1102
Questions
0
Helped
313078
Points
2384
At the top right corner of webpage
you'll see page /tools click the tools arrow and make sure you have no check beside workoffline
if you do remove the check
let me know if you still have problems
and please rate me
  • DEKR
    DEKR Feb 09, 2009
    do you still need help and please don't forget to rate me
    thanx
My laptop is really slow n it has all this pop ups and it desconect the wireless internet,
if your using internet explorer go to tools click on internet options then choose content tab then click on the box "turn-on pop-up blocker, for the wireless connection you can call your internet provider to check the wireless settings of the router
Compaq presario F500. Wireless internet connection not working. Internet works when plugged into modem. D-Link wireless modem working perfectly. Constant red/orange light on next to wireless switch at...
Hi, Thanks for using fixya.
When you connect it to wireless make sure you go into control panel / network view your connection right click on local area network connection choose disable then connect to your wireless connection. Right click your wireless icon by your clock choose connect to wireless network or view available local wireless connection.
Terry
I have a embarq 660 series router and using a compaq presario computer. I have already installed the belkin surf/share wireless USB adapter to this laptop. When I go to Internet explorer it says offline.
your problem is a IP address conflict
Embarq and Belkin have the same IP address 192.168.2.1
change the IP address in to your Router.
To restore the router to factory default settings, please do the following:
1. Unplug the router's power supply
2. Press and hold the reset button on the bottom of the router
3. Keep the reset button depressed and, at the same time, plug the power supply back in
4. Keep the reset button depressed for another 10 seconds
5. Release the reset button
======================= Manually configuration ==============================
Step 1 : Connect modem - Router - Computer ( Wired )
Step 2 : Open router setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3 : On the left side under internet WAN click Connection Type
Step 4 : leave the Password Blank and click submit
Step 5 : Choose the connection type as dynamic and click next
Now go to lan settings and change the IP address 192.168.2.1 in to 192.168.1.2
Step 6 : Leave the Host name blank and click apply
Step 7 : On the left Under Internet WAN Click MAC Address
Step 8 : Click Clone and Click Apply changes
Step 9 : If the Internet status on the top right is connected
Step 10 : Then check if you have internet
Step 11 : if not Then unplug the Power Cable from the Modem And the Router
Step 12 : Plug the power Cord to the Modem
Step 13 : Wait till all the lights are on
Step 14 : Plug the power to the belkin
Step 15 : Check the color of the light in the belkin
Step 16 :If green then Check if you have internet
If not working then call belkin
=================== WIRELESS SETTING UP A WIRELESS CONNECTION ====================
Step 1 : Connect Router - Computer ( Wired)
Step 2 : Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3 : On the left under wireless click wi - fi protected setup
Step 4 : Leave the password blank and click on submit
Step 5 : Disable it and Click on apply changes
Step 6 : On the left under wireless click Security
Step 7 : Enable 64 Bit WEP
Step 8 : Type a 10 digit number on the key 1 ( 2 in each box )
Step 9 : Click apply changes
Step 10 : on the left under wireless click channel and SSID
Step 11 :Change the Wireless channel to 6
Step 12 : Change the SSID to a different name ( no Spaces )
Step 13 : Click apply changes
Step 14 : Now Scan and connect to this network ( Wireless )
Let me know if it works
1helpful
Using Compaq Presario CQ50 - Even though wireless internet shows connected in lower right hand corner icon, when attempting to access internet get message, "Internet Explorer cannot display the webpage",...
it could be an issue with proxy on the browser.
To solve it :
click on tools on internet explorer at the top, go to internet options, clikc on connection tab, click on LAN settings, and uncheck proxy settings nad click ok. then refresh the page and check if you are online.
Wireless internet on compaq presario 6425 tu
Do you know for sure there is a wireless connection in the area you trying to connect, Wireless internet isn't accessible every were and when it is available it could be protected by a security pass phrase. The only way to really get full use out of your wireless internet is to go to a company that sells the wireless internet cards
I just installed a D-Link DIR-655. My desktop is running just fine but my laptop won't connect wirelessly. Well it says I'm connected to the network but when I click on Internet Explorer it says, " Can not...
I think what we're dealing with then is a Windows Firewall problem, for whatever reason its blocking Internet Explorer and Safari from the net. The globe is proof that even Vista can see internet on your connection. We need to allow those programs through your firewall.
http://windowshelp.microsoft.com/Windows/en-US/Help/df3de57e-86d8-4cd7-808d-9907561b21bc1033.mspx
Internet explorer and Safari are the ones we are looking for. Let me know if this helps. Unfortunately my vista machine is at home or else I could give you more precise instructions.
Internet Explorer cannot display the web page
Have you installed any software firewalls lately, I know Norton has a habit of randomly blocking the internet.
Try disabling any firewall you may have and try again, if the internet surfing problem persists, try plugging in a wired connection and seeing if you can surf from there.
HOW TO CONFIGURE WIFI WITH Compaq Model C765TU in XP
Click Start, then select Control Panel.
Click Network and Internet Connections. The Network and Internet Connections window opens.
Click Network Connections. The Network Connections window opens.
Right-click Wireless Network Connection.
Select Enable to turn on wireless Ethernet or Disable to turn off wireless Ethernet.
Top Compaq Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ExpressFiX
ExpressFiX
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
