Have tried all codes I can find and none will work. The remote will not accept some of the codes (tv light will not blink 3 times after code is entered). I have gone through the auto-detect procedure several time and have got nothing.
Check these codes. 506, 520, 525, 536, 564, 565, 566, 567,
568, 569, 573, 575, 610, 710, 712. If you wish to get more details and setup codes, check this link.
SOURCE: dish network remote
i would suggest trying power scan again...
1)hold down tv button next to sat button in top left corner
2) when all buttons illuminate press 500 into remote
3)press pound sign
4)Hello, please help..
5)hold town tv button again.
6)when all buttons illuminate press big red power button
7)press up arrow once a second until tv shuts off
8)press # pound sign
9)try to turn tv back on w/ big red power button
10)if tv doesnt turn back on try again from step 2 but use down arrow instead
if this doesnt work try addressing your old remote to the receiver by pressing record from system info screen
SOURCE: need codes for a phillips magnavox for dish network controller
Follow this link and got to the remote section. Once there shoose the type of remote you have and select remote codes to get the ones for that particular remote that may operate the piece of equipment desired. I hope this is of assistance to yoiu and thanks for using Fix Ya. Please let me know if I can be of further assistance.
Jim
SOURCE: My dish network remote isnt working with my LG tv
Not all TVs are supported by our remotes. You can do a power scan to see if you can find one that works or you can get the newest remote type that supports a large array of TVs. The new rmote is a model 21 which will work in IR and UHF mode. To perform a power scan do the following: Press and hold the upper left TV button on the remote until all lights on top light up and release.Now press the small red TV button and release - the upper tv button should be lit solid. Now press the arrow up key slowly until set turns off. Once it does presss the arrow down key once and then the arrow up key and the TV should power on. Now press the pound sign and the rrecord button. Now press the upper SAT button and release . You should be able to control the set now. Thanks for using Fix Ya.
SOURCE: what is the tv code for a VIORE TV model LCD19VH65
http://www.remotes.com/ here is a link i use
SOURCE: Dish Network IR Remote's SAT Mode Not Working ____
Hello, this is Nick Franta with DISH.
If you are trying to get the remote programmed to the receiver you can remove the smartcard from the receiver and that will prompt the system info screen. This will allow you to program the remote to the receiver.
If you need the process for programming the remote, here it is:
Hope this helps!
