The controller is not getting the correct feedback signal from the SMPS (switched-mode power supply AKA inverter).
It may be a problem with the inverter, magnetron, magnetron thermostat, controller, or thew wiring that connects them.
There should be a "mini-manual" (tech sheet) hidden inside
the unit behind the control panel or hidden on the left side behind the grille,
which is very helpful when troubleshooting, testing, and locating components.
You can see a YouTube video
here that shows you how to remove the
controller assembly from a typical over the range microwave in less than 5
minutes.
You can find see the parts list with helpful exploded
views and download manuals for it here:
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=XXX&siteCd=WHRCOM&userType=Consumer
NOTE: You must change the XXX in the URL above to your
exact model number with suffix (but no dashes) as shown on the tag in the
cooking cavity or on of the oven. Then copy & paste it into your browser\'s address box.
You can buy part from
the Pros here, our favorite supplier.
We\'re happy
to help you with free advice and we\'d appreciate your thoughtful rating
of our answer.
SOURCE: Whirlpool Velos Microwave showing "Error
F7 means that the control panel is not getting feedback from the Switched Mode Power Supply (high-voltage inverter).
This could be due to a problem with the inverter or the control unit / circuit board, but it appears to be the latter in most cases.
We repair microwave control boards for customers nationwide with our guaranteed $39.95 service.
We have full details, plus critical safety, disassembly, and troubleshooting info at our site. You'll find a link to our site in our listing here on FixYa: http://tinyurl.com/yzjozk
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful.
You may reply back with your brand and model number if you'd like us to look into this further, or feel free to contact me directly if you need more help.
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
[email protected]
http://www.microwavedisplay.com
