Nikon D100 Digital Camera Logo
Cheryl Tester Posted on Feb 10, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Will not take picture
Batteries are charged. view finder is dim and camers will not take a picture. Auto focus working.
Anonymous
Level 3:
Guru:
  • Master 2,178 Answers
  • Posted on Feb 13, 2013
Anonymous
Master
Level 3:
Guru:
Answers
2178
Questions
0
Helped
390760
Points
6614
If the view finder is dim it is likely the iris of the lens is stuck and cannot acquire correct lighting. It need to be repaired by disassembling the lens.
4 Related Answers
Anonymous
  • 619 Answers
  • Posted on Jan 03, 2008
SOURCE: Camera will not take pictures in Auto Focus Mode
visit www.lensbabies.com
Anonymous
  • Posted on Jan 16, 2009
SOURCE: Focusing problem
Well, stupid me, I didn't realize there is a diopter adjustment button directly to the right of the viewfinder. I would NEVER have known it was there, but after asking my photo-nerd friends all of a sudden the solution was apparent. Still a wasted day of shooting, but hey now I don't have to look like an idiot taking my camera somewhere to be serviced!
Anonymous
  • 86 Answers
  • Posted on Apr 09, 2009
SOURCE: View - Finder reads "OFF"
Firmware problem. That's why the D70s and D70 are discontinued.
Anonymous
  • 175 Answers
  • Posted on Feb 28, 2010
SOURCE: how to take a picture using display instead of view finder
I don't believe there is. Nikon call it Live View in other models, but its not mentioned in the D40 user manual.....
here's the full manual, if you'd like it.
http://safemanuals.com/user-guide-instructions-owner-manual/NIKON/D40-_E
Argued for almost a year over focusing problems and methoding and "r13" problems which they said was a bad connection between the lens and the camera. When the guarantee ran out we insisted the store
The D90, is a very good camera. I even know some professionals who do have one or more, to work with or have it as a backup for a bigger Nikon, because it will work with almost every Nikon lens. That means, it also works with the older AF lenses, that were made for analog (film) cameras.
To start, put the main dial on the top left, to the green camera (auto) logo or the one with the line through the flash logo, next to it. In both cases the camera works automatic , with a little difference. In auto it will pop up the speed light when there is little light, in the other it will raise the ISO and will not use the flash. without flash, if there is not enough light, the camera just won't make a picture.
when you are in one of the automatic settings, see in the view finder, where the camera will focus while you press the shutter half. It will place one ore more squares on one or several parts of your frame, where the camera "thinks" it should focus on. It this or these parts are the points you like to be in focus, then press the button full.
this should give better pictures. If it works, let me know.
Out of focus pictures when shot with view finder
I had a problem similar to this. Try taking off your glasses or removing your contacts and try again. Best of luck.
1helpful
My grand daughter got as a gift the disney enchanted princess pink digital camera with no instruction booklet. we plugged it in to our computer to charge nothing is happening. is there an instruction...
It need two AAA batteries to work. Insert that batteries and turn on the camera by pressing the push button on the top.It cant work without battery even if it connected to computer.
for taking picture,focus it on an objest using view finder and press the shutter butten.
3helpful
2answers
I have a canon powershot sx20..looking through the view finder looks blurry,but after takingt the picture and looking on the screen the picture does NOT look blurry...It's only blurry when looking through...
Your camera is equipped with a optical diopter that will allow you to adjust the optics in the viewfinder to your eye. meaning bringing everything into focus as it should. The way I use this (set it) is to let the camera auto focus on a subject and then turn the diopter until I see the subject clearly.
It really helps if the subject is about 12 feet away (get it real sharp) and the camera is mounted on a tripod. Once set I put a little dot of paper white out on the diopter adjustment knob so if it gets turned I know and can quickly return it to the correct spot. I'm including a diagram where this adjustment knob is on your camera, have fun.
Diagram
When I take a picture with the Canon Rebel, it doesn't focus in the view finder, but when I look at the picture after it has been taken, it is clear and in focus. Why can't it looked focused when looking...
Good day,
The problem you might be having is that the view finder is out of focus.
If this is the problem it is an easy fix.
You will see a small wheel next to the view finder (it has a + and a - next to it), look through the view finder and let the camera focus on an object. Now turn the wheel and you will see the image either get worse or start to come in focus. Adjust the wheel until you are satisfied with the clarity.
Please let me know if this was helpful!
Regards
2helpful
Brand new Canon EOS Rebel XS. Suddenly, image in the view finder is blurry. Auto focus seems to be working, and pictures are coming out fine. But sometimes, the autofocus focuses on the wrong thing, and so...
Next to the viewfinder ther is a diopter adjustment so you can change the focus in the viewfinder. this is so if you need glasses the camera can be set for you. Start by focusing the camera on something, then slide to turn the diopter adjustment until it looks sharp and try not to bump it.
Camer keeps shutting off...it's burry and powers
Digital cameras require lots of power. Bad electrical contacts can cause lots of problems so battery and camera contacts must be cleaned properly. Batteries may be fully charged, but will be viewed as low if contacts are not really good. The LCD screen is a low steady load, but when lens extension, optical zoom, focus, and flash charging are added in the capture mode; the load is very heavy. Bad contacts make cameras do strange things like making bad pictures or shutting off with the lens out.
Do not overcharge.
Reset by removing power up to one month is the ultimate non-physical repair for DVD recorders and other software using digital devices. Digital cameras reset to original settings if batteries are removed. Time required varies with function and camera, but try one minute. Check display and setup menu for non-auto functions and date/time. Remove extra memory to eliminate this as a possible problem. Insert fully charged batteries and restart the camera.
Finder focus problem
is there a little slider type bar/switch/button on the finder, most cameras have them to compensate for different peoples eyesight. if there is, look through it, put camera in auto focus and when its focused, look through finder and move bar/switch... til pic is clear
3helpful
Nikon N55 Won't take picture in Auto Focus Mode?
There was a recall on the N55 due to auto focus problems. You can do a google search or nikon.com email the support team and they will send you the paper. This is what I did, I wasn't charged since I had the correct papers. I, however, used one roll of film and my focus went out again! Mine doesn't even work on manual... If you want to try that maybe you will hae better luck than me. GOOD LUCK!
1helpful
3answers
Image blacked out on LCD and can not see image in view finder
This is a defective CCD known to Canon. They will repair it free of charge. Go here for details: http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=223&modelid=8044&keycode=2112&id=29819
Top Nikon Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Nikon Camera Expert? Answer questions, earn points and help others
