My 1992 chevy caprice classic stalled out while driving, started up after and I drove it home. A few days later while going to take it to the mechanics to get it looked at it wouldn't start and now it's getting no spark. It's getting fuel fine just no spark.
SOURCE: 1995 chevy caprice classic
Try replacing your fuel pump relay, Its common on chevys.Those fuel pumps are too expensive to keep replacing
SOURCE: I have a 1995 Chevy
Mine did the same thing - not sure if yours is a 5.7 liter or not. Mine is, it's the LT1 engine and has the police package. Not sure if it's the same with the smaller engine, but if it is it could be something leaking over your distributor (water pump, coolant line,leaking oil getting sprayed upwards by the serpentine belt) which is an opti-spark. They are terrible and are labor-intensive to replace. It can be expensive and time-consuming unless you find someone who REALLY knows what they're doing - which isn't easy these days. Look up opti-spark, everyone hates it.
SOURCE: 91 chevy blazer 4.3 won't start after running.
Check the ECM for Codes to help you find out what's causing the problem. Here is a simple and easy way to check.
On board diagnostic (OBD) was designed on vehicles equipped with electronic fuel injection so you can generally retrieve the codes yourself. No need buying a scanner or running to any parts stores to check the Check Engine. This system is called obd1 and applies to most vehicles made before 1995 for domestics and 1993 on imports. In this article, I will discuss the methods used by domestic vehicle manufacturers on how to check the engine lights in their cars and Trucks.
For GM domestic vehicles made before 1995, the diagnostic connector is located under the dash panel by the driver side. To get the check Engine codes to flash in your dash panel, use a jumper wire or a paper clip and connect terminals A and B of the diagnostic connector. Turn your ignition key on with engine off and the codes should start to blink. All codes should start with code 12 which is one long flash followed by 2 short flashes. This code 12 means the diagnostic system is normal and will repeat itself continuously if there are no trouble codes. Otherwise, code 12 will flash 3 times before flashing the fault codes.
Counting the codes being flashed is easiest way to trouble shot problems in domestic vehicles and most of the codes can be erased or cleared by disconnecting the battery negative terminal for 1 minute and reconnect. Just make sure to check your service manual in case you have electronic equipment such as radio or clock that needs reprogramming in which battery disconnection is not recommended. Finally after performing repairs on the culprit code, always go for a road test to confirm if the problem is fixed.
Here is a link with the GM codes. http://chevythunder.com/199295_lt1_trouble_codes.htm
Good luck and hope this helps
SOURCE: 97 Chevy Lumina Completly Stops while driving
i need location of where this tcc solenoid is located on 97 chev. lumina so i can change part
