Visual Basic .NET (VB.NET) is an object-oriented computer programming language that can be viewed as an evolution of Microsoft's Visual Basic (VB) which is generally implemented on the Microsoft .NET Framework. It is a competing technology to Sun's (now Oracle's) Java 2 Enterprise Edition framework.
firstly you have to create a database and in that you have to create tables as per your requirement.
secondly, create forms in vb and connect the database, as per your requrement. it is not possible to give all the codes. use some e-books.
In VB6 you would use ADODB. This is for ADO and is used for accessing data (read, write, update, etc.) from different data sources. Your connection string will vary based on the data source you need to connect to. Here is an example for a SQL connection:
One of three ways:
1 make the table using vb creating a Bload screen.
2 using the visual data manager.
3 import a windows access or excel data base table.
Try the data wizard, easiest to use and U can program the program to manipulate the data in the tables.
