Check out stovedecals.com. USA company and there are a ton of stove stickers and stove Decals available, and they even make them custom if your stove model isn't on there.
I had a very similar problem with my oven so I contacted www.ovenlettering.co.uk who supplied me with excellent quality replacement decals with super fast delivery!
The video on the website made it easy to apply them too
SOURCE: Ariston FM22 Oven No Control decals
Go to this site www.appliancepartspros.com and look up your model there and you can order the decals or replacement knobs there.
SOURCE: ge double wall oven repair
You need to tell us the model number. I can then give you specific information.
SOURCE: Overlay Panel bubbles up!
I had the same oven panel overlay bubbling problem on my GE oven purchased in 2008. It started peeling and bubbling within the 1 yr warranty, and GE sent me a replacement panel. This new part began bubbling again within 4 months. Again, I called but now they say it's out of warranty and they will not replace it. Obviously there's a manufacturing defect in this part. The panel looks terrible. It appears that GE no longer cares about the quality of their products.
SOURCE: dcs oven display dim - need part #
I just did this same repair...same part number as above (Part #211696 "Electronic Oven Control, Double).
to install you have to remove two screws on the top of the display section of the oven, as well as several screws on the bottom of it, and the screws holding the close pin/temperature probe socket.
Then you can pull off the whole top section (slowly) and remove the two connectors to the existing control unit.
Then release the ribbon cable connected to the control unit on the inside of the top section (press the two small pins inward and slide up the small front section of the black socket to release the ribbon connector.
Unscrew the old control panel, screw in the new one, connect the ribbon, and then reverse removal steps. Easy!
SOURCE: GE Monogram Trivection - self-clean cycle with oven racks in
Hello- First off, do not use 'self clean', or as most Techs call it: "Self- Destruct". This 'feature' cheerfully sold by the salesman destroys more oven and range components than any other failure. Now- the racks had a thin layer of grease on them when the oven tried to turn stuff inside the oven to ash. The grease is now a hard rubbery coating on the surface of the rack. To solve this problem, you must determine by observation, where the rack touches the sides of the oven. These contact areas need to be cleaned thoroughly with scotchbrite and a small portion of oven cleaner. Make sure you use gloves. Sliding rack in and out to 'mark' these small spots works pretty good. Once cleaned and wiped down, they should work fine. I recommend cleaning by removing as much 'stuff' by scraping and wiping down with moist cloth. Turn on to 450deg for 30 min. Much safer, less costly. Please acknowledge this posted solution if helpful. Have more info if needed- Thanks -Ed
I had thesamrobem an contacted www.ovenlettering.co.uk who suplied me with really good quality replacement decals and super fast delivery!,Hope this helps
