Need fitting instructions
Call the manufacturer, Bath-Knight, in the United Kingdom for assistance. 0800 083 3608
https://bath-lift.co.uk/
What in the world is a bath sling?
Rod
US Parts Center
SOURCE: what products to us in my jet bath
Bubble bath is definitely out of the question. Provide any of the products that you are using do not have a detergent base or bubbles so to speak, you can use them. Depending on how many times a week you use it you might want to get a cleaner that they use on hot tubs from you local pool distributer. I hope this helps you.
SOURCE: How do I use my Whirlpool bath?
youneed to make sure that the switch is on first .their should be a switch for the tub on the wall somewhere.find the switch than push the button on the tub,also make sure that their is water in the tub that is past the jets before pushing the button on the tub.
SOURCE: I know I can take a bath without turning on the
The soapy water will fill all of the jets, tubes and the pump assembly. Will it hurt the tub if the jets are not running? The soap film will build up in the jets, tubes and pump assembly and can possibly cause damage if the tub is run at a later date. Contact the tub manufacture and see if there is a safe bubble bath you can use.
SOURCE: whirlpool bath won't turn on.
Most of the control buttons on a tub are not electrical. These buttons are connected to an air line that runs to the motor. Sometimes an aggressive button push can literally blow the air line right off of the bottom of the button.
This problem is as easy to fix as it sounds. Find the loose air line and push it back onto the button. You will need to open up your access panel. Bring a flashlight.
Be sure to check the connection at the motor too. Good luck
