It is a generic scientific calculator and not feature rich. It can calculate trigonometric functions, exponentials, logs, powers, combinations and permutations. You must have an idea about what you are calculating in AC circuits and figure out, by reading the manual, what calculations can be performed on this basic scientific calculator. The manual is available online at education.ti.com
Two keys can be used to enter negative exponents on the TI-30Xa scientific
calculator; the [y^x] key or the [EE] key. The [y^x] key is used for
all exponents while the [EE] key is used for scientific notation only. The
examples below will demonstrate how to use both keys:
1) Entering
7^-2.
• Press [7] [y^x] [2] [+/-] [=]. • The calculator will display:
0.20408163.
2) 1*10^-3.
• Press [1] [EE] [3] [+/-] [=]. • The calculator will
display: 0.001
You can put it in scientific notation by hitting 2nd and 5. It will put your answers in scientific notation and not round that particular answer you have.
Hello, Your calculator has 3 memories (M1, M2,M3) To store the number 170 in M1 use 170[STO]1 To recall a number from M1 use [RCL]1 To add a number to the content of M1 [2nd][SUM]1 (adds displayed value to contents of M1). [2nd][EXC] 2 exchanges the value already displayed with the contents of M2:
To erase (clear) a memory register, just store 0 in it.
1. To convert a number to scientific equation, use [2nd][Sci]
Exemples 12345 [=] screen shows 12345 Then [2nd][Sci] coverts it to 1.2345 ^04 to the power 4.
2. To enter directly a number in scientific notation (e.g. -1.2345 X10^(-65) a very small number) you use the [EE] key 1.2345[+ /-][EE][+/-]65 shows as -1.2345 -65
1.6X10^(-19) 1.6[EE][+/-]19 shows as 1.6 -19
If you mean using the "EE" key it's straightforward.
To enter scientific numbers, enter the number, then press EE, then the exponent value. The TI-30XA will stay in scientific display until you "clear" or turn it off. It will also switch to scientific notation if you multiply big numbers that exceed the display.
E.g. Input 3, EE, 10, X, 3, EE, 10, =, gives you the answer 9 times 10 to the power 20. Press the "square root" key and you will get back 3 times 10 to the power 10.
You can mix entries too, e.g. 3, EE, 10, X, 2, =, gives you 6 times 10 the power 10....
