hmmmm, monitors don't usually have audio output but from the info I can find on this model it doesn't appear to have speakers. I could be wrong though.
I recently was given a MAG Model 780 too. I found the input for speakers just today. When looking at the monitor, on the left side behind the monitor you should be able to feel a flat horizontal surface. If you lay monitor down, you will see 2 mini-plug openings. These are your input spots for speakers/microphone. I believe pink is speakers & green is microphone.
No, it has a normal, seperate power cord. But the socket in the monitor is very small, it's a small round one. When facing the monitor from the back, it's located directly to the right of the monitor-stand, at the bottom-side of the screen. Just put the monitor on it's side to see it clearly.
If your monitor supports sound (might have to be the LT765s product?), there will be two inputs on the back (to the right when looking at it from the back). One's labeled "Line in." This is where you'd plug the audio cable from your sound card.
What is the sound card in your computer? I am pretty sure your speakers won't require drivers. Your sound card in your computer is what needs installed, I am guessing.
Sounds like an inverter problem. If the power supply is internal replace the capacitors coming out of the voltage regulators. These are usually 1000mf and/or 470mf. If that doesn't do the trick look up the numbers on the 8-pin chips that drive the secondary transformers on the inverter to see if they are getting the right voltages. Good Luck!
