HOW TO BLOCK NUMBER IN NOKIA C3
Hi
PUK code is called as PERSONNAL UNBLOCKING KEY.
Your phone will ask for PUK code when you entered the PIN code wrongly several times depending upon the mobile make. The mobile asks for PUK code so that unauthorized persons do not use your mobile for wrong cause.
To get PUK code please contact your service provider through phone or go directly to their office. They will provide you the PUK code for your mobile. The PUK code for mobile phone.so that you can open your phone. When you planning to call your service provider you cannot use your mobile as it is fully locked. Please use some other mobile with same network to call your service provider.
While you get the PUK code ,the service provider customer care officer will ask for your personal details to check whether the mobile belongs to you only. If they are satisfied with your answers they will provide with the PUK code
DONOT enter the PUK code several times wrongly,It will block your sim card permanently.
This PUK code is FREE. You no need to pay any sum to get the PUK code
Thank You.
SOURCE: Nokia 6301 - Can I block incoming text messages
hi..
SOURCE: how can i block a
The 6500c does not support conditional call forwarding (CCF) which is useful if your carrier does not provide blocking services. I have owned several nokia, a samsung, two LG, and currently have a blackberry 9330. If unwanted calls are a serious problem, consider upgradeing to a mobile phone that supports CCF. Conditional call forwarding can be used to forward any unwanted phone number includeing calls from unlisted, unknown or restricted callers. Depending on where you live, the call can be instantly forwarded to a service, such as trapcall.com, that unmasks the caller in addtion to providing the standard message "This number is no longer in service" for example.
A Nokia C3 unlocked mobile phone works on all GSM networks. The Nokia C3 needs a Nokia unlock code in order to remove the SIM lock that comes on most SIM based cell phones by default. If your Nokia C3 has a SIM lock on it, then it will prevent you from using the mobile phone with any other carriers.
I would first recommend you try getting a Nokia C3 unlock code by calling up your current phone carrier. In exchange, they will need your Nokia C3′s IMEI Number. Your IMEI number is unique to your mobile device and the Unlock code will be calculated using it. You can get the IMEI number on your Nokia C3 simply by typing *#06# and hitting the enter or send button.
