2001 Honda civic bad fuel in gas tank - Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1
the sender unit in the tank ,i think it has petrol in the float so its not reading correct.with the filler neck and associated pipes then it no doubt holds nearer 15 gals or about 80 litres .I couldnt afford to buy this much petrol in one go as its just over 1 euro 20cents a litre here so that would cost me 90+ euros or if the exchange rate is right this morning thats a dollar a litre
check for fuel pump hum by the gas tank with the key on, if no hum check fuses and relays (under the hood and dash) if they are good replace fuel pump. if you hear humming try replacing the fuel filter
This problem may be soved but it will take some work, You must drop the gas tank or have a mechanic do it for you and clean the tank out, and look inside to see if there is something inside of the tank,
Ok ready for this one,new gas cap,its true cars with bad gas caps will cause the check engine light go on,or your problem,it has to be pressurized when full and no air in the tank its ok,but as you use gas and have air in the tank with the low fuel the air pressure is leaking pass the cap,thus losing pressure,too bad you had to fix all the other stuff but look at it as an investment,after this works please give me a fix ya thanks
they are designed wih presure need to be in tank when you fill the car with engine runnig the gas cap removal will cause the engine to stall especially one with a week fuel pump.
remove rear seat, remove round metal cover, disconnect fuel lines and wires from top of fuel pump, jack up rear of car. remove gas tank straps, lower gas tank with a jack, install is reverse.....if you need to just replace the fuel pump you don't have to remove tank you Can access from under rear seat good luck and please rate -jeff
If the car has over 100,000 miles on it, you may need to replace the distributer. I don't think the bad gas caused this issue I think it may just be a coincdence. But if you already changed the plugs, wires, distributor cap, and rotor, I would definetly check the distributor.
