HP 12c Calculator Logo
Posted on Jan 26, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
HP 12C When I calculate for "N", my answer is always rounded up, can this be adjusted?
Anonymous
Level 2:
  • Expert 56 Answers
  • Posted on Jan 27, 2009
Anonymous
Expert
Level 2:
Answers
56
Questions
0
Helped
24241
Points
111
IF I REMEMBER THIS IS A PROGRAMABLE CALCULATOR RIGHT, YES IF IT IS PROGRAMABLE, NOW YOU HAVE AN ANSWER TO THE MILLION DOLLAR QUESTION HOW TO DO IT MY BE ON THE INSIDE OF THE COVER OF THE DUST COVER .
HP MAYBE ABLE TO FIND SOMEONE TO HELP YOU.
HP FORUM CHAT LINE, HELP LINE, USER GROUP, OLD COMPUTER CLUB, FRIENDS WORK AROUND ENGINEERS MY HAVE THE KNOWLEDGE, OLDER CLIENT TELL.
PROGRAMS OLDER USER GROUPS, EVEN CHESS PLAYS THAT USE PROGRAMABLE CALCULATORS TEXAS INSTUREMENTS.
CANDYMANGANDY
How turn off the rounding key on a hp 12c Calculator
hp12c
7 years old
manual is free to read
on page 83 is your answer
https://www.manualslib.com/manual/277109/Hp-12c.html?page=83#manual
omg i read your manual for you,....
How to fix my hp calculator 12c numbers display is faint?
There is no contrast adjustment possible with the 12c. Most of the time, faint displays are due to weak batteries or poor contact with the battery or batteries.
1helpful
Do you have advice in calculator choice between HP 12 c and the TI BA II Plus Professional Financial Calculator? Assuming that I get proficient with RPN (which I'm learning now); is one faster than the...
The 12C is more expensive and more powerful than the BAII+Pro. The HP is also programmable, which the TI isn't. Starting from scratch (assuming you've never used a calculator before---a somewhat unreasonable assumption) the TI might be easier to learn, at least initially. But after a certain point, the HP will leave the TI behind. The HP is faster and more capable.
There are at least three different versions of the 12C available. There's the original 12C, the 12C Platinum, and the current 12C. The only way to tell the difference between the two non-Platinums is to look at the battery compartment---the original uses three button cells while the newer uses two coin cells. The newer one is MUCH faster. The Platinum, however, can use RPN or algebraic.
Unless your choice is limited to the 12C or the BAII (by the requirement of an exam, perhaps), you might want to look at the HP 20B and the HP 30B. Programmability aside, they're even more powerful and easier to use and faster than the 12C, and the 30B is also programmable.
There are other considerations, of course. Factors such as the feel of the keyboard, the 12C's landscape orientation as opposed to the others' portrait orientation, etc, are all matters of personal preference.
Disclaimer: I own multiple HP and multiple TI calculators. I tend to use HP calculators for calculating, while I use TI calculators to answer questions here at FixYa.
I accidentally DELeted the L1 and L2 on the STAT -> EDIT rows, are there anyway to fix that?
I assume you're not talking about an HP 12C but a TI calculator of some type.
You can always recreate a list. For example, to create L1, press 2ND { 0 STO> 2ND L1 ENTER
Wrong answers
Most likely it's the process not the calculator that is failing. But there are so many things that could be shifting your results...
Are you rounding your values to two decimal places as you go? Because with accounting of very large numbers you need to not round until you get your final answer. The .001 cents lost each time you round a subtotal adds up and in the case of several millions of dollars can cause a few hundred dollar discrepancy.
Also, if you're calculating accrued interest make sure that you are compounding it correctly. Amounts compounded continuously will give you a dramatically different amount than interest compounded monthly or annually.
Finally, if you are using the memory function on the calculator make sure that you are pulling that value in correctly.
I have an HP 12C calculator and I cannot find the user manual and I cannot remember how to change the no. of decimal places?
Check this HP FAQ:
Setting a Fixed Decimal Place You can download the manual and user guides for your calculator from here:
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&product=81575&lang=en&
For more information, Faqs & how-Tosgo the HP support homepage for your calculator:
http://h10025.www1.hp.com/ewfrf/wc/product?lc=en&dlc=en&cc=us&lang=en&product=81575&
Introduction This document describes how to set the desired number of decimal places on the HP 12c calculator in standard format. It also covers how to enter a number in scientific notation. Instructions for standard format
  1. Press and release c01774993.jpg .
  2. Press the number key for the desired number of decimal places to be displayed to the right of the decimal point (0 through 9). The calculator displays a maximum of 10 digits.
The display will show the specified number of decimal places. The answer will be rounded to the number of digits selected. Example (standard format) If the number in the display is 14.87456320, the display will be changed as follows: Keystroke Display c01774994.jpg 14.8746 c01774995.jpg 14.9 c01774996.jpg 15 c01774997.jpg 14.87456320 Instructions for scientific notation Use scientific notation for very large or very small numbers. Type in the mantissa. After pressing, c01774998.jpg the next numbers keyed in are exponents of 10. Press c01774569.jpg . If during an operation a result has more than 10 digits, the calculator automatically displays the number in scientific notation
How can i tell the difference b/w hp12c and hp12p. i bought a hp12p from ebay(it's a stupid decision, I know!) and when i solving for IRR, i felt its running quite slow. I think the guy sold me the hp12P...
I couldn't find any reference to a HP calculator model 12p.
There is a HP 12c financial calculator and a 12c Platinum financial calculator.
Check both models (for images, specifications, functions, user guides, etc.) :
HP 12c Financial Calculator
HP 12c Platinum Financial Calculator
HP 12C -- Rad error
Here is the self-test procedure for your calculator. If it does not answer as it should, it may need service. Sorry, I resized the picture but FixYa refuses the new dimensions. Hope it helps.
39helpful
I want to increase the number of decimal places
I found this solution on the HP website. Turn it on, and do what it says. Then turn it off and back on again, and the extra decimal places should show.
http://h10025.www1.hp.com/ewfrf/wc/document?dlc=en&lc=en&cc=us&docname=bpia5183 Introduction This document describes how to set the desired number of decimal places on the HP 12C Calculator in standard format and in scientific notation. Instructions for standard format
  1. Press and release the gold PREFIX key (f).
  2. Press the number key for the desired number of decimal places (0 through 9).
CENTS
I'm doing this from memory because my 12c is at home, but I believe that there is a "fix" key. You need to enter shift-fix-2 (this will set the decimal places to 2).
Dan
k24674
Grand Canyon Tech
Grand Canyon Tech
