From the Home Menu swipe down to get the pull down menu. Select the gear on the right hand side which is Settings. Select the Language option which you'll probably have to figure out by translating the word Language to whatever language the tablet is current set to.. If the menus are in the same order as in English it should be immediately after the Keyboard option which you may have to translate to the tablets language. The first option under Keyboard sets the language for the table. Select the first option. If those options are in English select English.
*#66*# Set Factory Mode CONFIRMED *#8375# Show Software Version CONFIRMED *#1234# A2DP ACP Mode CONFIRMED *#1234# A2DP INT Mode CONFIRMED *#0000# + Send : Set Default Language CONFIRMED *#0007# + Send : Set Language to Russian CONFIRMED *#0033# + Send : Set Language to French CONFIRMED *#0034# + Send : Set Language to Spanish CONFIRMED *#0039# + Send : Set Language to Italian CONFIRMED *#0044# + Send : Set Language to English CONFIRMED *#0049# + Send : Set Language to German CONFIRMED *#0066# + Send : Set Language to Thai CONFIRMED *#0084# + Send : Set Language to Vietnamese CONFIRMED *#0966# + Send : Set Language to Arabic CONFIRMED
More some codes for reset mobile china *#77218114# *#881188# *#94267357# *#9426*357# *#19912006# *#118811# *#3646633#
CHINESE MODELS:
default user code: 1122, 3344, 1234, 5678
Engineer mode: *#110*01#
Factory mode: *#987#
Enable COM port: *#110*01# -> Device -> Set UART -> PS Config -> UART1/115200
Restore factory settings: *#987*99#
LCD contrast: *#369#
software version: *#800#
software version: *#900#
set default language: *#0000# Send
set English language: *#0044# Send
set English language (new firmware): *#001# Send
also ========== Service codes BenQ: software version: *#300# test mode: *#302*20040615#
Service codes Pantech: software version: *01763*79837# service menu: *01763*476# reset defaults (phone/user code reset to default): *01763*737381#
Service codes 3xx, 5xx: software version: *#79# software version: *#837# Service codes VK200, VK2000, VK2010, VK2020, VK4000: software version: *#79# service menu: *#9998*8336# (hold #) reset defaults (phone/user code reset to default): *#9998*7328# (hold #)
Service codes LG: software version: 2945#*#
Service codes Sony-Ericsson: J100 software version: #82#
Service codes Fly: 2040(i) reset defaults: *#987*99# Send MX200 reset defaults: *#987*99# Send MX200 software version: *#900# Send SL300m reset defaults: *#987*99# Send SL300m software version: *#900# Send SL500m reset defaults: *#987*99# Send SL500m software version: *#900# Send MP500 reset defaults: *#987*99# Send MP500 software version: *#900# Send Set language to English: *#0044# Set language to Russian: *#0007#
Service codes Konka: C926 software version: *320# Send C926 set default language: *#0000# Send C926 set English language: *#0044# Send
Service codes GStar: GM208 (Chinese Nokea 6230+) engineering menu: *#66*# Set language to English: *#0044# Set language to Russian: *#0007#
ZTE Mobile1- *938*737381# 2- PHONE WILL DIPLAYED DONE 3- POWER OFF YOUR PHONE AND POWER ON AGAIN alcatelE205 unlocking phone code,only press***847# without simcard
E900 software version: *#5002*8376263# E900 full reset: *2767*3855# Service codes Spice: S404 enable COM port: *#42253646633# -> Device -> Set UART -> PS -> UART1/115200 S410 engineer mode: *#3646633# S900 software version: *#8375# S900 serial no: *#33778# Service codes Philips: S200 enable COM port: *#3338913# -> Device -> Set UART -> PS -> UART1/115200
Service codes Pantech: software version: *01763*79837# service menu: *01763*476# reset defaults (phone/user code reset to default): *01763*737381# Service codes VK-Mobile 3xx, 5xx: software version: *#79# software version: *#837# service menu: *#85*364# (hold #) Service codes VK200, VK2000, VK2010, VK2020, VK4000: software version: *#79# service menu: *#9998*8336# (hold #) reset defaults (phone/user code reset to default): *#9998*7328# (hold #)
Service codes LG: software version: 2945#*# KG300 NVRAM format: 2945#*# -> menu 15
Service codes Fly: M100 software version: ####0000# 2040(i) reset defaults: *#987*99# Send MX200 reset defaults: *#987*99# Send MX200 software version: *#900# Send SL300m reset defaults: *#987*99# Send SL300m software version: *#900# Send SL500m reset defaults: *#987*99# Send SL500m software version: *#900# Send MP500 reset defaults: *#987*99# Send MP500 software version: *#900# Send Set language to English: *#0044# Set language to Russian: *#0007#
Service codes Motofone-F3: Motofone F3 software version: **9999* Send ***300* Set SIM Pin ***310* / ***311* SIM Pin ON | OFF ***000* Reset Factory settings ***644* Set Voicemail number ***260* / ***261* Auto keypad lock ON | OFF ***510* / ***511* Voice Prompts ON | OFF ***160* / ***161* Restricted Calling (Phonebook only) ON | OFF ***200608* Send: software version ***200606* Send: software version ***200806* Send: flex version ***250* / ***251* Keypad tones ON | OFF ***470* Select time format ***500* /***501* Prepaid Balance Display ON | OFF ***520* Change language
