20 Most Recent
Microsoft Surface RT Questions & Answers
Outlook Icon of the Start Page
Hello, now when I want to have a program on my Home Page in Windows 10, I go to the left-side of your tiles, near the top, I think it is the small icon third down from the top, and place your mouse marker on it. You will soon see that it says All Applications. Click that and all the Applications or programs that are installed on your computer will appear in lines. Now if you place your Mouse Pointer on the one you require and click it, the dialog box that appears will ask if you want to place that Application on your start screen, or your Task bar, you will just click it and it will then go to the desired place, or if you want to remove it you do exactly the same action. Hope this helps.
3/24/2019 11:45:31 PM •
Microsoft...
Answered
on Mar 24, 2019
Will not turn on
Try having the charger on at the same time. Hold the on button on longer than normal. This is what I did, hope it works for you.
12/14/2016 2:08:45 AM •
Microsoft...
Answered
on Dec 14, 2016
How do I download bitlord onto my pc
The official download link is below.However I suggest that you don't use it to download pirated material. Illegal Bit torrents are the primary method for criminals to install malware on your machine.
BitLord the easiest torrent downloader If this is your intention...I look forward to your question on how to repair your operating system, why your bank account, games or girlfriend/boyfriends accounts have been compromised, or why your computer is suddenly running slow.
3/20/2015 11:48:43 AM •
Microsoft...
Answered
on Mar 20, 2015
Half the screen is black
The white dots are most likely to be failed pixels in the LCD screen. When the picture elements fail, they switch to clear and what you see as white is the backlighting.
The overheating issue in laptops is generally caused by dust and fluff blocking the cooling fins and ducts or a failed cooling fan, but it could also be caused by a hung process which runs the CPU at a high processing speed. Press control (CTRL) ALT and DEL and look at the task manager and see if you can see any processes that are running constantly near or at 100% to eliminate this being the problem.
The failing display is unlikely to be related to the overheating issue.
3/20/2015 11:22:10 AM •
Microsoft...
Answered
on Mar 20, 2015
How put program downloaded by disc from laptop to surface
The Microsoft Surface has a USB connect.. if the software is compatible for Win 8RT you can copy to a USB thumb drive then copy to the surface,, you might also to try a portable CD/DVD connectable with USB,, newer laptops don't have a DD/DVD.. you can purchase one on Amazon for about 100,00
3/16/2015 11:18:07 PM •
Microsoft...
Answered
on Mar 16, 2015
