Had same problem. Lift up rear seat on drivers side and you will see a steel tube running from the wheel arch under the seat. Tube is about 2 inches wide. If this is rusted underneath then water is getting via the wheel arch open end of the tube. It runs into the rear foot well and forward into drivers footwell, also runs under rear seats and into the boot! I removed the rear drivers side wheel, pulled away the plastic wheel arch lining then sealed the hole where the wiring leads through this pipe. Covered it with plastic flashing replaced the wheel arch lining. Took 30 mins to repair, took a week to dry the carpet, rear seats and boot carpet.
