A router was configured in my friend's laptop and it is working properly. His brother has a laptop also and the router signal can be received by that laptop but the problem is when the browser is opened, error results just like when a connection is not available. I cheched everything including the TCP/IP address and the settings are all automatic. What's the matter?
Check with this tip
Let me know if everything is clear and if you can put every setting matching on both sides: Access Point (= router, AP) and Client (PC).
Radio connection IS different from browsing Net.
Can PC browse internet when connected with LAN cable to same router?
Are both on same subnet?
Have you checked if an access list is installed in router firewall?
Is the Client blocked /allowed in Firewall?
Can you ping router from Client?
Did you see the router as default gateway in Client IPCONFIG?
Is Router IP address in HOST client file?
Any antivirus, firewall (like Zonealarm) software blocking some new LAN connection and requiring to unblock?
way?......
