2010 Chevrolet Traverse Logo
Looking for solutions Posted on Jan 16, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
2010 chevy traverse front therostat went out
What could it be?
Anonymous
Level 2:
New Friend:
Greenhorn:
A rookie expert who has answered 20 questions on their first day.
  • Expert 74 Answers
  • Posted on Jan 16, 2013
Anonymous
Expert
Level 2:
New Friend:
Greenhorn:
Answers
74
Questions
Helped
11403
Points
247
5 Related Answers
Anonymous
  • 41 Answers
  • Posted on Apr 05, 2010
SOURCE: 2009 Chevy Traverse with 3800 on it, w/ low coolant
good question with it being a 2009 i'd ask chevy
Anonymous
  • 126 Answers
  • Posted on Apr 02, 2011
SOURCE: How to change headlight vulbs for chevy traverse
look in the front wheel well there will be a round hatch to take off.. u might have to turn ur front tire hard over or take it off
XKarDoc
Terry Reimink
  • 458 Answers
  • Posted on Jun 16, 2011
SOURCE: 2010 chevy traverse air conditioner
The two problems are more than likely related. Solve the voltage problem and the blower problem will disappear. Check for a slipping belt or an intermittent internal problem with the alternator. There could also be a wiring issue.
Anonymous
  • Posted on Jul 22, 2011
SOURCE: 2010 Chevy Traverse in garage.
I have the same problem
skychief2001
Stephen
  • 21873 Answers
  • Posted on Dec 11, 2012
SOURCE: wheres p0050 code on 2010 chevy traverse
Code 50 is for the heater circuit in the O2 sensor for bank 2 sensor one. That is the sensor on the side with cylinder 2 and in front of the catalytic converter. Could be a faulty sensor or the circuit for the heater in the sensor.
Does a 2010 Chevy traverse engine fuse box fit on a 2014 Chevy traverse
Compare, they are listed as different.
Chevrolet Traverse (2009-2017) fuses and relays
https://fuse-box.info > chevrolet > chevrolet-traverse-20...
Fuse box location. It is located underneath the instrument panel, on the passenger side, under the cover.
2010 Chevy Traverse and both L/B headlights went out. Fuses and bulbs are good so what could the problem be?
https://www.autogenius.info/chevrolet-traverse-2010-fuse-box-diagram/
Did you also check the LB headlight relay. If LB and HB relays are the same you might want to switch them to see if Low Beam will start working.
fuse box diagram in link above.
How do i wire up a trailer light harness to a 2010 chevy traverse?
Get a plug and play kit. They are usually available from your local parts store. This will save a lot of time and make the install much easier for about $30 us.
Rigid Connector
I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_d728a59f986299fa
3answers
How much lbs of freon do I put on a 2011 Chevy Traverse?
theres a sticker under hood should be up on front radiator support
How many gallons of antifreeze does chevy traverse take 2010
Most systems will take 3.5 gallons completely empty.
Chevy traverse 2010 ac is blowing hot air
try the ac fixes(freon recharge) found at your local autoparts store if that works for a little while you have a leak in the ac system if it makes no change it is most likely the ac compressor or the ac pulley is not engaging
Help me find low pressure ac port for 2010 chevy traverse
We're can I fine the low pressure cap in a Chevy AC traverse
Replace cabin air filter on chevy traverse 2010
2009 chevy traverse- where is the cabin air filter located. It definatly has one but ??? where.
13helpful
How to change headlight vulbs for chevy traverse 2010
Top Chevrolet Experts
ZJ Limited
ZJ Limited
john h
Thomas Perkins
Thomas Perkins
Are you a Chevrolet Expert? Answer questions, earn points and help others
