SOURCE: Phone Security code forgotton
Here you are:
Switch on your phone without a SIM card.
Usually you should use code number 7.
If it does not work, try code 1. Different codes work on different phones.
Remember that you only have 5 tries.
After that you have to leave it to a unlock shop.
To enter the code:
1. Push #
2. Push * 3 times in one second. (p will show)
3. Push * 4 times in one second.(w will show)
4. Push * 2 times in one second(+ will show)
5. Enter the code from below.
6. Push * 2 times in one second.(+ will show)
7. Enter the code number
8.Push #
Now a message like "Sim restriction off" should be displayed. That means your phone is now unlocked.
Your code's are:
#pw+423337355155033+1#
#pw+335956562371552+2#
#pw+408817632640012+3#
#pw+926572751457775+4#
#pw+835201163324600+5#
#pw+126364753455061+6#
#pw+795800321340200+7#
SOURCE: unlock security code for nokia3110c
Hi sir, i have nokia 3110c and i have forgot the security code which i had changed from default i.e 12345..and the new security code i had forgot...please help me out to unlock mine phone as if i have mine important contact numbers and data in dat phone pls help me out for this...
SOURCE: reset security code..default code 12345 doesn't help cause i had change it before
The default code is 12345. And if you want to reset the security code, then you can use the code below:
*#7328748263373738#.
This works on most of the Nokia phones.
cheers.
SOURCE: I had forgotten my nokia 2600 security code plzz help me
I had forgotten my nokia 2600 security code plzz...
SOURCE: forgot security code
please dial *#7328748263373738# this will reset your security code to 12345
Hi
The default Security code is 12345.
If you changed it and
forgot the security code please contacts your device dealer. They will provide
you the default security code so that you can use your phone.
This security lock
prevents thieves from being able to make use of stolen handsets that is why it
can only be unlocked by authorized device dealers.
Thank You
Hi
This security lock
Thank You
Hi
This security lock
Thank You
