FreeMotion Fitness XTr Folding Treadmill Logo
Posted on Jan 08, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Belt is slipping - FreeMotion Fitness XTr Folding Treadmill
ernesto cuadra
Level 3:
Top Expert:
  • FreeMotion Master 12,223 Answers
  • Posted on Jan 08, 2013
ernesto cuadra
FreeMotion Master
Level 3:
Top Expert:
Answers
12223
Questions
0
Helped
4081330
Points
34431
See the video and fix it. God bless you
Belt slip on reebok edge 2.2 when wlking. Tightening fixed the slip but still slipped on running. Even with the hex keys at the tightest it slipped. I checked the belt on the motor and it looked OK?
Frequently Asked Questions - Reebok - Reebok Fitness
https://www.reebokfitness.com/.../FAQItem_-1_20101_30652_faq-tread
Jump to How can I loosen or tighten the walking belt? - ? Play this video Treadmills have two different styles of walking belt adjustment. To see which type ...
Reebok Edge Treadmill 2.2 - YouTube
? 1:49
https://www.youtube.com/watch?v=fWjbWV8f6wE
Aug 27, 2011 - Uploaded by redgoals
Reebok Edge Treadmill 2.2 ... and I feel when jogging im gonna fall off the end of it - I cant see a man using this at all - maybe just for walking.
running machine belt slipping? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Jul 17, 2012 - i have recenty purchased a reebok edge series 2.2 treadmill but when i run in it the belt slips foreward then carries on the way it ... I sounds like the belt needs to be tightened. ... Walking belt on treadmill slips under pressure?
Why is the new belt on my dirt devil featherlite repeatedly slipping off? Everything else on it works fine and the b elt is the correct size.
Hello! There is no other part that goes on the motor shaft after the belt is put on. The tension of the belt keeps the belt from slipping off. If you have a brand new belt that keeps slipping off you may not have the correct belt for the vacuum. Be sure you replace with a genuine Dirt Devil belt and the specified belt style for your particular unit. Hope this helps! If you still need assistance feel free to reach out to us here on Fixya, Facebook.com/dirtdevil, or Twitter @DirtDevil.
2answers
What makes a belt squeak?
Belts squeak for the same reason tires do when they spin. They are slipping. Something isn't turning as fast as the belt wants it to. On ford it's usually ether the idler sprocket or the tensioner. If you remove the belt and try spinning all of the pulleys by hand.( note the crank wont spin freely) you will usually be able to tell witch ones slipping.
1helpful
While using my Nordictrack a2550 this morning, the walking belt began to slip very badly. I checked the alignment and adjusted the tension of the belt as per the user's manual but the belt stills slip...
if it really is the walking belt that is slipping keep tightening the adjustment screws till the belt will not slip when you try to stop it ( set speed to about 3 and then with your foot try to stop belt from spinning - you should be able to make the motor and whole machine come to a stop ) make sure it is really walk belt spinning and it isnt the motor belt slipping. (if it is motor belt slipping when you try to do the stop the belt trick i just described you will see the walk belt and front roller stop but still hear the motor turning) once you get walk belt tight enough so it doesnt slip then you can worry about keeping the belt centered.
let me know if you need more help on this and let me know how the stop the belt test went
good luck!
Belt seems to be slipping
As a general rule, the belt should be kept as loose as possible. However, the belt must not slip on the rollers in normal use. Possible overtension can be quickly checked by walking on the belt at a speed of 3 mph The belt must slip on the front roller if you brake the belt with your feet, holding onto the hand rails, while you walk. If the belt does not slip, the tension is too high and the rear roller must be loosened. The belt tension and alignment is done by adjusting the rear roller position with the attachment bolts at the back of the treadmill a 1/4 turn at a time until correct tension attained. T
The belt slipped
The belt has probably slipped down below the carrier, it's easier to take the shaft out, install the belt then put the shaft back in. Be sure to turn the shaft top to the front with a 1/4 in. wrench to lock it in place.
DickyO
Treadmill is slipping. Already tried tightening belt ... I could hear belt slipping as motor is turning
This sounds like either the drive belt is loose or the walking belt is old. First, check the tension on the drive belt. If the drive belt is not slipping, then walking belt may need to be replaced. I say may because without working on the unit, I cannot say that IS the problem.
Belt stops/slips
Sometimes tightening the belt is not the problem> What I would be doing is to get on the machine a determine which of the belt is actually slipping. What happens if the drive belt is glazed slippage occur no matter what you do. With the running belt you may have to it limits of adjustment and the belt can be stretched that no matter how you adjust it it will slip!!
8helpful
Belt slipping have tried to tighten, just bought used
When the belt slips, it can be 2 different places. The trick is to look at the front roller when the belt slips. If the front roller stops with the walking belt, then the drive belt (between the motor and front roller) is loose and can't be fixed by tightening the walking belt. If the drive belt is slipping, it needs to be tightened or replaced. I need the brand and model number to help you further.
Belt slipped off machine
rotate pulleys while trying to reinstall belt. if belt slipped off on its own then belt is streched out. replace belt
Top FreeMotion Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
john h
ADMIN Andrew
ADMIN Andrew
Are you a FreeMotion Exercise and Fitnes Expert? Answer questions, earn points and help others
