SOURCE: fatal error
this error points to locked files during startup, only known to me solution is complete removal of autocad from the system, it as well be indication that insufficient or faulty memory in the system.
i would suggest removal of autocad, reboot, install ccleaner, remove of all junk and clean of registry, then clean re-install of autocad,
if you have less than 512mb ram on winxp or less than 1024mb ram on vista, it can be a problem as well.
SOURCE: While Removing AutoCad 2006 :FATAL ERROR:
This error could be occuring due to the fact that the Application is targetting a dll from an older version.
Uninstall all versions of Revit and Reinstall Revit Architecture 2011 as per the link below:
http://usa.autodesk.com/getdoc/id=TS13712572
I hope this works for you. Kindly reply for further assistance. Good Luck!
Thanks for using Fixya!
Mongkey
"Understanding explains better..."
