2003 Mercury Mountaineer Logo
Anonymous Posted on Jan 06, 2013
2003 mountaineer V8 Temp gauge jumps to hot not over heating. Replaced thermostat, no change
2003 mountaineer V8 Temp gauge jumps to hot but not over heating. Replaced thermostat, no change. Engine reduces power and check engine comes on. If I turn car off for 10 seconds the temp returns to normal.
ANDRE
Level 2:
Habit-Forming:
New Friend:
  • Expert 61 Answers
  • Posted on Apr 15, 2014
ANDRE
Expert
Level 2:
Habit-Forming:
New Friend:
Answers
61
Questions
0
Helped
19662
Points
137
Can you have a feel of the radiator once you start in the morning is it hot all through once the thermor opens, does the fan comes on once it is hot. Do one thing put the A/C on and go for a spin see what happen.
Let Us know
AD
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jan 14, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
716
Points
The Engine Temp. sensor is bad. it is under the intake manifold. if there is a miss also check under the coils over the spark plugs. If there is Coolant in the spark plug holes .then the intake gasket is leaking. The intake manifold needs to come off to change the coolant sensor. When off look for corrosion on the cylinder head at the coolant port. If there is corrsion then the cylinder head must be replaced.
2 Related Answers
Anonymous
  • 60 Answers
  • Posted on Mar 10, 2011
SOURCE: I have a 2000 Mercury
The overheating and lack of cabin heat both point to a failed engine thermostat which would be stuck closed. At the warm up stage, the coolant stays in the engine block to bring the engine to efficient operating temperature, then it opens and circulates the coolant through the radiator and heat core. If the thermostat is stuck closed, the engine will overheat, and coolant will never reach the heater core, and you will not get cabin heat.
Blinking oil light at idle which goes away during driving could be a low oil level, but may also be a drop in oil pressue. You could have a clogged oil fliter (at best) pickup tube, or a failing oil pump.
Anonymous
  • 123 Answers
  • Posted on Mar 10, 2010
SOURCE: False temp reading
you will find that there is nouthing wrong all that is a bad reading due to a faulty body earth! seen it all before! just check your body earth points it will be one of those loose! or corroded!
think it's one underneeth the drivers side foot well plastic pannel I think? but it is definetly one of them stop worrying! you will find it easy now you know what it is!
Hope that helps (shuld do!)
1helpful
2answers
What can be causing my 2003 tiburon to over heat?
I do not think this is thermostat , in city driving if it was thermostat the issue would be worse , if you have something clogging the radiator fins , mud , leaves etc... this could cause an overheat
I have a 1991 Cadillac SeVille 4.9 V8. It drives fine most of the time until it warms up in the afternoon. Then it starts to sputter and not want to drive. I have replaced the fuel filter,thermostat
Hi Crystal , There are a number of components on you vehicle that can cause this , ignition modules have been known to cause this problem, crankshaft position sensor , MAP sensor , coolant temperature sensor ! Is the check engine light on ? It wouldn't be the fuel because if is plugged hot or cold it's not going to change An a thermostat could cause the vehicle to over heat or not get to normal operating temp. your temp. gauge would show hot or cold ! You should take it to a repair shop , don't guess an just start replacing parts ! that can get expensive .. Making Sense of Engine Sensors
Honda Pilot 2003, low engine temperature, thermostat was replaced several times, still the engine temp is low.
use a termo laser to check temp of coolant at filler cap ,with cap off run vehicle till you have hot heat coming out of your heater then check with laser. if it reads above 140 then you know 2 things . either the therm sensor is going bad or the temp gauge is bad , make sure the radiator fans come on ,if they do and you have good heat then you have bad gauge.
1996_gmc_sierra Heat gauge started going from 260 degrees back to normal. I replaced heat sensor then thermostat. This summer had complete radiator and cap put in. The gauge says its running at 230 an
My Mountaineer had a similar problem. When driving it, the temp needle would slowly go up and up for like 3 minutes then it would come down within about 30 seconds. Then it would slowly rise again. just kept doing this over and over but it never went too high. My gauge didn't have numbers on it but it would go up about half way (not near the too hot level though) then fall back down to about a quarter of the way on the gauge. Found out that the fan clutch was bad on my radiator fan. It was not engaging and disengaging at the right times. New fan clutch solved the problem and probably saved the engine from overheating eventually if it had gotten even worse.
2answers
My truck starts running hot then I turn the heater on and it blows cold air but every once in a while the heater will throw out hot air. Then the temp gauge will go down. I've check med the radiator cap...
I'd still check the thermostat. Or basically just replace it. Have you ever drained all the antifreeze and flushed the system? Good time to do both. If the hose's get real hot that doesn't really mean the thermostat open. Wouldn't they get hot even if the thermostat didnt open.? If the thermostat was stuck open you'd would have cold air and low temp gauge. Then maybe hit a pump or something and have the thermostat stick closed and have high temp. Maybe water pump. Check it when you have the belt off. Spin, pull & push the water pump pulley around. I'd replaced my water pump at about 110,000 on a '97 dodge Dakota. My 97 never had a very good heater. Always heated up more after driving. Idle never got it warmed up.
1helpful
What causes a 2003 mercury mountaineers temp guage to go from cold to hot then back to normal in seconds while driving.
There could be a number of causes of a fluctuating temperature gauge but most commonly is the thermostat. It could also be a head gasket, cooling fan problem or the actual temperature sending unit. I hope this helps!
1helpful
2answers
2003 Mercury Mountaineer no heat
no you have to remove the vent between the hood and the windsheild its on the out side of the car it sounds like your freshair vent is stuck open
Top Mercury Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Arnie Burke
Arnie Burke
Are you a Mercury Expert? Answer questions, earn points and help others
