SOURCE: Lost manual for BTSLBC3
Go to http://www.fixya.com/support/t1267258-pairing_problem_supertooth_btslbc3 All solved! :)
SOURCE: I have misplaced my manual
Try going to manualsonline.com they have most any manual there that you can download free.
SOURCE: how long do i have to charge the stanley j309 300 amp battery booster
Before the first use, the unit must be charged for 24 hours with a connection to an AC outlet (120V). Make sure that all of the switches are off. After that, stop charging when two red and one green LED Battery Status Indicators light.
If you are recharging the unit from a 12V battery, do not charge for more than 6 hours. (Check for a full charge by disconnecting the DC charging adapter and then press the Battery Power Level button.)
The manual for the Stanley J309 battery jump starter is available on the product page here: http://www.baccusglobal.com/stanley/j309.php . The direct link to the manual is http://www.baccusglobal.com/stanley/manuals/JUMPERS/J309%20MANUAL.pdf .
I hope this helps.
SOURCE: How do I know the battery status on my Stanley 350
I have a more basic version from Home Depot. From day 1, the charge indicator never worked correctly. Have had it several years now and probably by this time, the battery is just getting weak and needs to be replaced. I found that charging by the cigarette lighter doesn't work too well. Charging by the AC adaptor overnight is the best and I do it every 4 months. Once and a while, I test it by connecting to an old starter motor. If it spins at decent speed, the charge is OK. The cigarette lighter plug connection is also good to use when you need to change the car battery and don't want to loose all your radio presets. It backfeeds the system and keeps all battery powered systems powered when the main battery is disconnected.
NEVER run the engine without the main battery connected! Good way to burn out all your electronics.
