Ovens Logo
alvin Posted on Dec 30, 2012
How do I place the door bac on - Ovens
timdurniak
Level 1:
New Friend:
  • Contributor 18 Answers
  • Posted on Dec 31, 2012
timdurniak
Contributor
Level 1:
New Friend:
Answers
18
Questions
0
Helped
222916
Points
31
Based on your video - it looks like the hinge part that is on the door was not locked into place when you removed the door.
Using a screwdriver you should be able to pull that piece out and there should be a small locking plate that you can swing into place to keep the hinge out. Repeat on both sides. Then you slip the door back on, open fully and push the locking plate back in.
Here is a youtube video showing the proper procedure for door removal and replacement.
http://www.youtube.com/watch?v=vEcGuf1vgo4
1helpful
How to turn off the oven light when door is closed. My stove is 15 years old
  1. Check all the screws behind the oven door gasket - in place and tight.
  2. Check that the door gasket is installed correctly and with all clips locked into place.
  3. Check the center hinge receiver, all screws are in place for the front chassis support
  4. Check the underside of the range below the center hinge receiver and make sure all 4 screws are tight and in place.
  5. Check that the door hinges are installed correctly & both mounting screws are secure.
  6. Check that the hinge retainers are closed and not blocked by the hinge cover.
  7. Check the top of door liner with a straight edge - make sure the liner is not bowed more than the width of a dime.
  8. Loosen the door panel top screws to a "relaxed" state. Open and close the door and retighten screws.
  9. Check the light/latch switch assembly - if out of position or stuck in incorrect position.
  10. If everything checks out, and oven light still stays on, replace hinges.
Apr 02, 2018 • Ovens
How do I remove oven door
open the oven door all the way and look down at the hinges. there is a little locking clip that you swing into position that locks the hinge from closing. it might be stiff and need some cleaning depending on how old and dirty your oven is. Also you might have to push down on the oven door to make the hinge open fully to get the locking tabs into place. making shore that the locking clips stay in place and hold open the hinge as you lift the oven door slowly towards its closing position and you will see the whole hinge lift up from inside the oven cabinet and the door will just lift out. be careful not to catch your fingers. make sure the looking tabs stay in place during removal as the hinge is very hard to get back into this position again. re fitting is the reversal making sure that you have pushed the base of the door all the way back into the cabinet and push down on the as to open it to release the tabs.
Sep 23, 2016 • Ovens
2answers
Blodgett oven mark v 111 can cool down but not cooking
door switch need to be checked or repalce. you can put 2 wires connect together and turn on see motor is running, if it run that mean switch is bac...good luck.
Kenmore oven door fails to lock
1. Remove the pan drawer
2. With someone holding glass up, remove the four screws at the bottom of the door that hold the glass front to the door frame. Gently lower the panel about two inches until the side guides are below the door trim cap. Place out of the way so it doesn't fall over etc.
3. Keeping the door closed, use a spring puller to remove each spring from the hinge. (I made one out of a hanger and a screwdriver. Double thickness at the hook, wrapped and secured around the screwdriver to make a handle) If you do things this way be VERY careful. Be sure it is really strong and is not going to slip. The springs are really under tension and will shrink down about an inch from where they are hooked. (Be sure to support the door so it does not fall open when the springs are removed. It will just make things worse.)
4. After the springs are off gently open the door all of the way.
5. Pull down the hinge locks from the oven body and lift the base of the door up. This will lift the door hinges off of the mounts in the oven frame and allow you to pull the door away from the body.
6. Place the door on your box or workbench etc
7. Remove the two screws on each side of the door that hold the hinges in place. Remove the hinges.
Reinstallation is in reverse.
Hinge repair.
By placing the lower part of the hinge (by the axle) against a ruler I was able to see that the upper section was bent out on each hinge. To correct it I placed the hinge over a pair of 4x4 blocks so that it curved up in the center, and hit it a few times with a hammer. The metal was very responsive and quickly bent back into shape. Be careful here as you don't want to bend them too far. I actually went a little past true, wanting to get a little more push at the top of the door. I placed the hinges directly on the oven to see the difference and they looked good (Be sure to put a piece of cardboard or rag between them and the top to keep them from scratching the surface.
Put the hinges back in the door, screw it together and hang it back on the stove, replace the springs and the glass, and check your fit. Good luck.
3helpful
WHILE MAKING HOT CHOCOLATE THE OTHER DAY, THE MILK BOILED OVER AND SOME OF THE MILK WENT THREW THE SLITS AT THE TOP OF THE OVEN DOOR BETWEEN THE TWO GLASSES IN THE DOOR. IS THERE ANY WAY TO OPEN UP THE...
First, you will need a heavy blanket to place the door on once you have removed it from the oven. Open the door slightly, until it stays open by itself, about 15 degrees. Lift the oven door off of the hinges and place on the heavy blanket. (The hinges may snap shut when you pull the door up and off, but this is actually normal. It takes a bit of finesse to get the door back on the hinges if they will not stay out.)
Remove the 4 screws across the bottom of the door. Next, stand the door up with the bottom on the blanket and the front facing you.(Hold the door by gripping firmly around the middle edges to maneuver door)
Now, while holding the handle, remove the 2 screws that hold the handle on, unscrewing them just enough until the handle is free. (You do not want the spacers dropping off the screws) Hold the door together with one hand while placing the handle out of your way.
Once again, grab the door firmly by the middle outer edges and lie the door down, the inside facing down. You should be able to lift up the outer panel and glass and clean the inside of the outer glass.
Reverse the above procedure to reassembly the door. You can also take the door apart further if you have stains inside the other glasses. Here is a link to a schematic for your oven door.
http://www.searspartsdirect.com/partsdirect/partsdirect/showSubComp.pd?imageUrl=http%3a%2f%2fc.searspartsdirect.com%2flis_png%2fPLDM%2fR0211500-00004.png
4answers
I have preloaded the replacement hinge, but it appears that to remove the old hinge it must be unloaded. If that is true, how do you load the new hinge while it is on the door?
Ovens come in many varieties including freestanding units and stacked models that are inserted into a wall. Kitchen oven units that get a lot of use or are getting old may have problems develop, such as a loose or squeaky door which may require replacing the hinges. You can replace the hinges on the door to your oven by first removing the door from the rest of the oven.
jQuery('.intro .thumbnail').each(function(i,e){ jQuery(e).find('img').one('error',function(){ jQuery(e).remove(); }); }); Difficulty: Moderate Instructions Things You'll Need:
  • Screwdriver
  1. Step 1 Open the oven door and examine the hinges to see how the they are secured to the door. Some oven doors slide into the hinge assembly or have a locking mechanism that secures the door to a latch on the main unit.
  2. Step 2 Remove the door from the oven by disengaging the locking mechanism and then pull the oven door out. You may need to release a catch on the door or remove a pin from a hole in the hinge.
  3. Step 3 Place the door on a flat surface such as a table or the floor.
  4. Step 4 Remove the screws that hold the sections of the door together to access the hinges.
  5. Step 5 Remove the hinges from the door. The hinges may be attached to the door with screws or they may be held in place when the door sections are tightened or secured.
  6. Step 6 Insert the new hinges into the door and secure them with the screwdriver or place the section of door back on. Tighten all of the screws securing the sections together.
  7. Step 7 Place the oven door back into place by sliding it on the same way that it came off.
Regards
Iversh
Jul 24, 2010 • Ovens
3helpful
Yesterday I cleaned my inside glass of my cooker (moffat94971100) The sealant popped and I have a loose glass. I have found sealant however how do I get the door off and weigh down the glass is there any...
Hi.
Normally there is a clip on both door hinges to allow easy door removal.
Once door is removed place on a towel on a flat surface. You will find a couple of screws on the top of the door and possibly underneath. Unscrew these and the two halves of the door should come appart. The inner glass is held in place with high temperatute oven sealant. You will need to thoroughly scrape the old sealant from inside inner door and on glass.
Apply sealant bead to inner door (but not too close to the edge) and then gently lower the cleaned glass on to the sealant. Press down gently. Now the sealant must have 24hrs to completely set so place a towel over the glass and place some heavy objects on the towel. House bricks are good if you have any.
Once dry you can then screw both door panels together and refit oven door.
Regards
Aardvark Repairs
Nov 16, 2009 • Ovens
2helpful
How to clean inside glass on oven door
If you can, usually it is possible, remove the door from the oven. open door to the first open position..(broiling) about 6" open then (make sure any screws are removed from hinges holding door in place) lift up and out at the angle the door sits.place on counter and start removeing screws. can be a whole bunch of em..
Oct 24, 2009 • Ovens
Whirlpool range RDE 6100N2
Instead of trying to place the bracket to the door from a lowered position at floor level, I positioned the brackets and from a standing position, placed the bracket into the slot, pushed in a downward position and the door went into place.
Top Ovens Experts
ZJ Limited
ZJ Limited
john h
Are you an Oven Expert? Answer questions, earn points and help others
