They have a service life of 10 years and have an inbuilt timer to let you know that by beeping. There should be a date on the underside of it. Remove it, look and if necessary replace it.
If the units are more than 5 to 7 years old they have reached the end of life cycle and need to be replace. Smoke detector typically are only good for 5 to 10 years.
Golding93, you could very well have elevated levels of CO in your home. You should leave your house immediately and call the fire department. However, if your CO alarm is 7 years old, it could also be the alarm's end-of-life warning. Regardless, you should definitely call the fire department to have everything checked out. If you need additional assistance with your CO alarm, please call our customer service line at 1-800-880-6788. Thanks for being a Kidde customer. We appreciate your business!
Tell me what brand your alarm is and I can help you with the beeping. Usually if you hit # it will silence the beeping for 24 hours. Something you can try is finding your main control box. Its usually located in the garage or in a closet. It is tan and 6 x6. First disconnect the battery inside the control box by jiggling off the black/red leeds. Then unplug the power supply. Wait five minutes. Reconnect the battery and plug in the control box. This is completely powering your system down and then repowering it up-essentially "re booting." If this does not correct the issue, give me the brand and I can further help you.
Push down on the tab at the top of the panel and open the front panel (Panel will say enter security code now). Put a slotted screwdriver in the top hole and depress to fold dowm the second door. Battery is inside the plastic case with two screws holding on the lid. The battery is a 6V 1.2AH battery
Recently I thought one of my kitchen appliances was beeping and it took an hour to discover that the real culprit was a dying battery in a nearby smoke alarm.
