When I hook up the battery it auto starts and runs for 10 seconds then turns off, then does it once more. For a year it's been a yard ornament. I tried new battery, same thing. I just want to completely disable it. Even before this it was nothing but problems. As soon as I hook up the battery it starts the motor. I had the remote battery checked,. My van is a basic nice looking useless piece of junk. Any help would be GREATLY appreciated.
Thank you, Wes
First, is it an alarm, keyless entry, remote start, or combination of the three? if you're SURE its just a remote start, you need to find the control module. it will probably be a black box, probably a bit larger than a pack of cigarettes. you can usually identify an aftermarket component by its wiring; it wont look like it fits with everything else that the factory put in there. a dead giveaway is red power wires with an in-line fuse holder in them. THIS IS NOT FACTORY WIRING, THEY PUT THEIR FUSES IN THE FUSEBOX! the module should be either in the driver's kick panel area, or up under the dash around the steering column. when you locate the non factory wiring with the in-line fuses, pill them out. done. if you have any problems, email me at [email protected]. (i am a mecp first class certified installer with >10years of experience)
