This is for 2008 TBSS 6.0L LS torque specs. should be the same. Hope this helps!
Connecting Rod Bolts - First Pass
20 N·m
15 lb ft
Connecting Rod Bolts - Final Pass
85 degrees
Crankshaft Balancer Bolt - Installation Pass to Ensure the Balancer is Completely Installed
330 N·m
240 lb ft
Crankshaft Balancer Bolt - First Pass - Install a NEW Bolt After the Installation Pass and Tighten as Described in the First and Final Passes
50 N·m
37 lb ft
Crankshaft Balancer Bolt - Final Pass
140 degrees
Crankshaft Bearing Cap M8 Bolts
25 N·m
18 lb ft
Crankshaft Bearing Cap M10 Bolts - First Pass in Sequence
20 N·m
15 lb ft
Crankshaft Bearing Cap M10 Bolts - Final Pass in Sequence
80 degrees
Crankshaft Bearing Cap M10 Studs - First Pass in Sequence
20 N·m
15 lb ft
Crankshaft Bearing Cap M10 Studs - Final Pass in Sequence
51 degrees
Cylinder Head M8 Bolts - in Sequence
30 N·m
22 lb ft
Cylinder Head M11 Bolts - First Pass in Sequence
30 N·m
22 lb ft
Cylinder Head M11 Bolts - Second Pass in Sequence
90 degrees
Cylinder Head M11 Bolts - Final Pass in Sequence
70 degrees
A "band pass" filter attenuates all frequencies except those in its specified range. A "low pass" filter attenuates frequencies above a specified frequency (permitting only lower frequencies to "pass"). A "high pass" filter attenuates frequencies below a specified frequency (permitting only higher frequencies to "pass").
For example, a "band pass" filter rated for 500MHz-4GHz will effectively eliminate all frequencies below 500MHz and all frequencies above 4GHz. A "low pass" filter rated at 10KHz will effectively eliminate all frequencies that are above 10KHz. A "high pass" filter rated at 70Hz will effectively eliminate all frequencies that are below 70Hz.
Please everyone that comes across my info take a few seconds of your time to rate my solution which you can select at the bottom of my answer Was this solution helpful? YES or NO :)... As i have taken time to answer your question the best i can Thank You......
If children use your Xbox console, you can set a pass code to
control access to features and options. Because Family Settings exist
for both the console and for Xbox LIVE accounts, you can set pass codes
for both. Here you can learn how to:
Set an Xbox LIVE Pass Code When
you set an Xbox LIVE pass code for your profile, anyone who wants to
use that profile will need to enter the pass code before signing in to
Xbox LIVE. To set an Xbox LIVE pass code:
Go to My Xbox and open your profile.
Select Manage Account, Xbox LIVE Pass Code.
Enter a four-button code using the X andY buttons, triggers, bumpers, and directional pad on your controller.
Confirm your code by entering it again.
To reset your pass code, repeat this procedure at any time. (You
will have to enter your original Xbox LIVE pass code before you can
create a new one.)
Set a Family Settings Pass Code When
you create a Family Settings pass code, anyone who wants to change
family settings on your console will need to enter the pass code first. You can also use your Family Settings pass code to override game
and movie settings if you (or those with whom you share your pass code)
want to play games or watch DVD movies that your console settings
normally block. For example, you could give the pass code to your 18-year-old so
that she can watch R-rated movies that your younger child is not allowed
to see. To set a pass code for your console:
Go to My Xbox and open System Settings.
Select Family Settings, Console Controls.
Select Set Pass Code.
Select Pass Code, then enter a four-button code using the X and Y buttons, triggers, bumpers, and directional pad on your controller.
Choose a pass code reset question.
Select Pass Code Reset Answer and enter
your answer using either your Xbox 360 controller or a standard USB
computer keyboard plugged into a controller port on your console.
Select Done from the Set Pass Code screen, then select Done once more from the Console Controls screen. When prompted, select Yes, save changes to put your new settings into effect.
To reset your pass code, repeat this procedure at any time. Reset a Forgotten Pass Code To reset your pass code after you've forgotten it:
Enter an incorrect pass code.
You'll be told that your pass code is incorrect. SelectReset pass code.
You'll then be shown your pass code question and asked to answer it.
Set a new pass code, following the directions in the previous section.
If you've forgotten the answer to your pass-code reset question as
well as your pass code, call Xbox Customer Support at 1-800-4-MY-XBOX
(1-800-469-9269).
