Question about Microsoft Xbox 360 Console
I forgot my family passcode and the answer to the secret question on my xbox 360 what should i do?
Posted by aureliogovea on
Nikki Mclean
  • 293 Answers
Hi aureliogovea
Please everyone that comes across my info take a few seconds of your time to rate my solution which you can select at the bottom of my answer Was this solution helpful? YES or NO :)... As i have taken time to answer your question the best i can Thank You......
If children use your Xbox console, you can set a pass code to control access to features and options. Because Family Settings exist for both the console and for Xbox LIVE accounts, you can set pass codes for both.
Here you can learn how to:
Set an Xbox LIVE Pass Code
When you set an Xbox LIVE pass code for your profile, anyone who wants to use that profile will need to enter the pass code before signing in to Xbox LIVE.
To set an Xbox LIVE pass code:
  1. Go to My Xbox and open your profile.
  2. Select Manage Account, Xbox LIVE Pass Code.
  3. Enter a four-button code using the X andY buttons, triggers, bumpers, and directional pad on your controller.
  4. Confirm your code by entering it again.
To reset your pass code, repeat this procedure at any time. (You will have to enter your original Xbox LIVE pass code before you can create a new one.)
Set a Family Settings Pass Code
When you create a Family Settings pass code, anyone who wants to change family settings on your console will need to enter the pass code first.
You can also use your Family Settings pass code to override game and movie settings if you (or those with whom you share your pass code) want to play games or watch DVD movies that your console settings normally block.
For example, you could give the pass code to your 18-year-old so that she can watch R-rated movies that your younger child is not allowed to see.
To set a pass code for your console:
  1. Go to My Xbox and open System Settings.
  2. Select Family Settings, Console Controls.
  3. Select Set Pass Code.
  4. Select Pass Code, then enter a four-button code using the X and Y buttons, triggers, bumpers, and directional pad on your controller.
  5. Confirm your code by entering it again.
  6. Choose a pass code reset question.
  7. Select Pass Code Reset Answer and enter your answer using either your Xbox 360 controller or a standard USB computer keyboard plugged into a controller port on your console.
  8. Select Done from the Set Pass Code screen, then select Done once more from the Console Controls screen. When prompted, select Yes, save changes to put your new settings into effect.
Reset a Forgotten Pass Code
To reset your pass code after you've forgotten it:
  3. Enter an incorrect pass code.
  4. You'll be told that your pass code is incorrect. SelectReset pass code.
  5. You'll then be shown your pass code question and asked to answer it.
  6. Set a new pass code, following the directions in the previous section.
If you've forgotten the answer to your pass-code reset question as well as your pass code, call Xbox Customer Support at 1-800-4-MY-XBOX (1-800-469-9269).
Posted on Jan 24, 2011
kenneth michael carter
    New Friend:
Swagg
Posted on Mar 12, 2013
Harold Maigrot
    New Friend:
X4We2nxp
Posted on Mar 21, 2014
2 Related Answers
Aaron Bennett
SOURCE: Forgot password to unlock family settings on xbox 360?
how the hell do you do it i cant find the device setting
Posted on Sep 27, 2011
Mykel_N
Mike Neath
  • 315 Answers
I've managed to come across this from someone who called microsoft with the same problem (it seems quite common)
Go into settings Console settings Then device settings (The one with the blue screen)
Then go:
left trigger, right trigger, x, y, left bumper, right bumper,
left with left stick, up with left stick, right with left stick, x
If you have trouble use the pad instead of stick, but I could only get the stick to work..
I hope that helps
Regards
Mike
Posted on May 27, 2010
How can i get my 4 digits family pass code. i forgot it
I hope you were the person that set it and not the person it is protecting!
Using a pass code and controlling access to ... - Xbox.com
https://support.xbox.com/my.../xbox-live-pass-codes Traduire cette page Use an Xbox Live pass code on your Xbox 360 to improve your account ... If you forgot your Xbox Live account pass code, download your profile from Xbox Live.
i forgot my own passcode - Xbox.com Forums
forums.xbox.com/xbox_support/f/9/t/275465.aspx Traduire cette page 17 juin 2012 - 8 messages - ‎8 auteurs I'm not quite sure if you've forgotten your XBOX Live accounts passcode or if you've forgotten your XBOX 360's Family passcode. But here's ... Resetting family settings password 19 juil. 2013 Help for Password 4-digit, Parental Control 23 juin 2013 Forgot my pass code and secret question 11 juil. 2012 on settings of xbox live I forgot the pass code. How do I reset ... 24 mai 2012 Autres r?sultats sur forums.xbox.com
microsoft account password reset, forgot ... - Xbox.com
support.xbox.com/en-US/.../lost-password-solution Traduire cette page If you forgot your Microsoft account password, learn how to do a Microsoft password reset online or by using your ... Do you want to reset your password online, or by using your Xbox One or Xbox 360 console? ... Error & Status Code Search.
reset Xbox 360 family setting passcode - YouTube
>? 1:13 https://www.youtube.com/watch?v=CsR8nK59c1M problem according to your Xbox 360 family setting. just go through the way explained in the flowing video.
How to reset xbox360 family setting if you forgot - YouTube
>? 2:08 https://www.youtube.com/watch?v=5_yep-0kaBI 23 nov. 2012 - Ajout? par Eric Martinez this is the pass code LT RT X Y LB RB DOWN DOWN DOWN DOWN on Dpad if that don't work try this one LT ...
Feb 04, 2016 | Microsoft Xbox 360 Console
I forgot my family setting passcode
You may need to take out the hard drive and do a factory reset
Dec 02, 2013 | Microsoft Xbox 360 Console
How do you factory reset the new xbox 360 if i forgot the family password
I had the same problem, call xbox live and they will surely help you
Feb 18, 2013 | Microsoft Xbox 360 Console
Family setting off the xbox 360 without knowing the passcode
Please contact the XBOX Support hotline to recover the default settings
http://support.xbox.com/en-US/contact-us
Nov 24, 2011 | Microsoft Xbox 360 Console
How do you change your family passcode
  • p.p1 {margin: 0.0px 0.0px 10.0px 0.0px; line-height: 19.0px; font: 14.0px Helvetica} p.p2 {margin: 0.0px 0.0px 20.0px 0.0px; font: 14.0px Helvetica} span.s1 {color: #006400}
    Navigate to to "My Xbox."
    Choose "System settings."
    Choose "Family Settings" if you do not subscribe to family pack and choose "Family Center" if you do subscribe to family pack.
    Choose "Set pass code."
    Choose "Pass code." Using the X and Y keys on your controller, input a four-digit pass code.
    Input the four-digit pass code again for confirmation.
    Select a code-reset secret question.
    Input the secret question answer. This can be done by either using your computer keyboard or the controller.
    Choose "Done."
    Choose "Yes, save changes."
  • Mar 20, 2011 | Microsoft Xbox 360 Console
    Then go:
    I hope that helps
    Regards
    Mike
    May 27, 2010 | Microsoft Xbox 360 Console
    I dont know where to find my secret question for my xbox 360
    If you go to the Hotmail website you will see 'Forgot your password?' link under where you would normally enter your password.
    From here you input your e-mail address, the security code generated and the next section will give you 2 options on how to reset your password :
    Use my location information and secret answer to verify my identity
    or
    Send password reset instructions to me in e-mail
    If you know your secret question you can input in there and hopefully you can then reset your password.
    If not then you'll have to e-mail Windows Live customer services regarding this situation and they'll probably ask obscure questions like :
    - If you have MSN messenger contacts and if so who are they
    - If you've used an Xbox 12 Month Prepaid Card what is the Serial number
    - What were your recent emails, recent contacts via email etc,
    - IP Address when logging in to the account or of your 360.
    Apr 18, 2009 | Microsoft Xbox 360 Console
    Microsoft Xbox 360 Console Logo
    3,435 people viewed this question
    Top Microsoft Video Game Consoles & Games Experts
    Ekse
    James Bradburn
    James Bradburn
    Lee Hodgson
    Lee Hodgson
    Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
