When you insert the full reservoir and turn on the machine it will make coffee, but all the while, water is running down the wall inside and leaking out the bottom all over the counter...help
SOURCE: breville ESP8XL Espresso Machine Cafe Roma leaking.. help please..
We had that happen and it was a crack in the black ring that holds the filter. Breville could not supply us with one but we found an OEM part in aluminum from http://www.vancouverwireedm.com/caferomadiyt.htm. We received it 1 week after ordering. It was pretty easy to replace. Our machine works fine now.
SOURCE: I have a Breville Cafe Roma Machine. I made about...
have you tried to use the sharp pin and try to dislodge coffee grind from the filter cup? You will need to remove it from the filter holder to gain access.
