Replacing the master cylinder on my sons 91 Buick Park avenue and I need to bench bleed the new mastewr before Iput it on the car. What am I doing wrong as I can't get the air out.
SOURCE: 91 buick park ave.
Well, that can be a ton of things. Usually it means: A. its not getting enough air, or any air. B. Its not getting enough gas. It could be a problem with the Mass flow Sensor- which can be cleaned or replaced-, or maybe a bad fuel pump or bad fuel lines or something. Either way the problem sounds like it just can't run because it can't get enough gas.
SOURCE: What is the llocation of a fuel pump for a1988 buick park avenue
Commonly submerged in the fuel tank. Some require the removal of the bottom rear seat, others need entire tank dropped to access.
If memory serves, you will need to drop the tank to access on the P.Ave.
Save yourself some time and pop off the rear seat just to be sure.
SOURCE: 92 buick park ave security light on car wont start
Someone put the wrong key (resistor value) in the ignition lock, you will have to disconect the battery for 3 min. Make sure you have the right key. Very important! Make sure the climate control is off before disconecting/conecting the battery.
SOURCE: having trouble replacing rearview mirror on 96 buick park avenue
it is held in the mirror mount with a small allen head screw.
I did refill it but the kit I got with the master cylinder allowed air to get in so I made my own bleederfixed the problem.
