I HAVE THIS GE JASCO 4- PORT USB HUB, AND ITS GIVEN ME A BUNCH OF **** EVER SINCE I GOT IT . THE NUMBER ONE PORT ( THE ONE BEING CLOSEST TO THE PC ) WORKS AND WILL LET A DEVICE WORK THRU IT. BUT THE OTHER 3 PORTS ARE TOUCH AND GO. T SEEMS TO HAVE SOMETHING TO DO WITH THE POWER USAGE OF THE DEVICE YOUR PLUGGING INTO IT. PORTS 2-4 ARE TOUCH AND GO THE WORK SOMETIMES IF i USE A LITTLE 256KBS FLASH DRIVE. BUT i TRIED PLUGGING IN A NUMBER OF EXTERNAL DRIVES AND A PRINTER INTO ALL THE PORTS AND NTHING WORKED. AND THE SAME PROBLEM WITH THE THE PC RECOGNIZING THE DEVICE , IVE HAD IT FOR MONTHS AND IT STILL HASNT NOT HAD ANY UPDATES COME THRU THAT HAD ANY TYPE OF DRIVERS OR IT. I WENT TO THE GE SITE FIRST AND FOUND THE HUB BY SEARCH AND THERE WERE SEVERAL VERY SIMILAR DEVICES ALMOST MIROR IMAGES OF THIS PRODUCT. AND I COULD NOT GET ANY DECENT SUPPORT WITHOUT PAY SOMETHING LIKE 2 U.S $ . I DONT KNOW IF IT WAS PER INCIDENT OR MINUTE AT THAT POINT I CLOSED THE SITE. NO WAY I AM PAYING FOR SUPORT ON A USB HUB. SO i FOUND THIS SITE THRU GOOGLE AND LOOK HOW MANY PEOPLE HAVE HAD PROBLEM WITH IT AND ALOT OF THE TEMP. RELATED AND NEARLY CAUSING FORES. MINE ALSO RAN HOT AS HADES. , IM SORRY BUT IT SEEMS TO BE A LITTLE MUCH TRANSFORMER FOR THE DEVICE. IM GOING TO TRY USING THE DRIVER POSTED ON THE PREVIOUS PAGE , AND IF IT DOESNT WORK AND LET MY PC RECOGNIZE IT ITS GOING TO GET A REAL NICE REVIEW IN MY COLUMN . AND THROWN AWAY.
SOURCE: unrecognized usb devices
If they work without the the expansion unit, the unit is not passing the power through. Many work this way. Some will work with external power.
SOURCE: When I plug a device into the hub, I can't locate it.
for usb hubs some of the port could fail any time so test all the ports to identify which one is working
SOURCE: i have 4 port hub
Hi, I went to the GE website on the same Hub, I have this one too. It does NOT list Windows 7 compatibility to use this hub with. Sorry. It lists all Other Windows OS, but Not 7.
HAVE THE SAME PROBS, ITS A MATTER OF TOO MUCH JUIE INTO THE PORTS HUB. i WOULD SUGGEST EITHER FINDING A CORRECT DRIVER FOR IT OR TOSSING IT. MINE WONT REGONIZE IT AND I have 2 different programs for drivers driver dr. which is what they want you to buy under that link the solution is here . well driver dr. found it but I cannot get the driver to install as t unloads into the device then at the end the procedure . bottom line ts a loser.
