Looking for a possible solution to my low speed left turn steering shudder, slow left turns at idle speed. Never wrecked, nothing bent, 102k miles. Mega cab 1500
The 2006 Dodge Ram 1500 goes from 0-to-60-mph in just over 5 seconds with a top speed of 150 mph. Hope this helps!---------------------------------------------------------
Multi-Diag Access
SOURCE: 1996 Dodge Ram 3.9L Pick up Steering Shudder
you could have air in the system. first try an fill the resevoir to a proper level then with engine running turn steering wheel all the way to the left until it squeals, then to the right till it squeals. repeat this several times if this doesn't cure the problem change the pump only I seriously don't that the gearbox is bad. please rate this
SOURCE: My 2006 Dodge Ram Mega cab makes a knocking noise
is it a 4X4? if so you got a axle joint knocking if just a 2wd ? then you have a bad shock or a wheel bearing problem
Testimonial: "thank you very much!"
SOURCE: I have some front end viberation in my 2006 dodge
There could be several causes. You could need your tires balanced, you might have unevenly worn tires caused by loose steering parts or worn shock absorbers. Have a tire shop check the tires. If the vibration gets worse when applying the brakes it indicates warped rotors. If they have not reached minimum thickness they may be able to be resurfaced - however - resurfacing removes more material and takes away their ability to get rid of heat, meaning they could warp again sooner. Fast driving and hard braking causes the heat that causes warpage.
SOURCE: 2006 Dodge Ram 1500 mega cab abs and brake lights stay on
check the sensors and connections may have loosened or knocked one loose if they look ok than have truck scanned most auto stores such as auto zone/advanced auto scan for free the trouble code will narrow the problem
SOURCE: I have a 2006 Dodge Ram 1500 4x4 thatbhas a
Have you tried changing tires and the brake rotors?
Anyone know a possible solution to the dodge ram low speed turn steering shudder?
