ur defalt phones codes is 12345 or 00000 u can use it Default 4 Digit user code: 1234 or 0000 Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile. send the IMEI no to me and i will reply you with unlocking code. IF Problem not Solved So Please New Software install in the Phone Problem will Solved
If For puk & pin cod problem So Please Very Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office oprator Enter The Puk code and Yes Enter The pin code and Yes So Puk code Open and Problem will Quickly Solved
I changed the battery and the wall charger , found out the earlier charger pin was faulty causing the screen to hang while trying to use during charging
Try the code *#7370# to hard format your phone then give the security code, if if doesn't work then try this:
¤ switch OFF the phone.
¤ press these keys together continueously *, 3, green key and ON/OFF button. The screen will show the formatting progress.
¤ take your hands off when the format completes.
Rate my answer...
hello there.. i think that's a phone problem that you yourself cannot fix. you need to go to a service center to let them check what's causing the problem.
but before you do, kindly answer the following questions i have for you:
1. did you recently download any types of application to your phone?
2. did you drop your phone?
here are various problems the lg ks660 touch screen could encounter. Although there are times when the screen does not work altogether, there are other situations when certain portions of the screen work and others don't. Press and hold the home button as well as the reset button on the top of the lg ks660 phone to turn the lg ks660 off.
do a reset of the phone and it should work if that is software issue if not than u need to open the front pannel and use contact cleaner and wipe the board
