20 Most Recent LG KS660 Cell Phone Questions & Answers
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Default 6 Digit Security code: 000999 or 1122
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
LG KS660 Cell... | Answered on Jul 05, 2017
Depending on where you downloaded it from, it should work fine.
LG KS660 Cell... | Answered on Jun 20, 2014
Follow the instruction given below:
Press "Home" > Settings >Privacy >Factory Data Reset
Read the message stating the types of data that will be deleted, then tap Reset Phone.
If you are certain that you would like to restore all factory settings, tap erase everything. Your phone will reset to the factory settings.
You can also use the method:
  1. Select Main Menu from the Home screen
  2. Tap Settings
  3. Scroll to and Select Phone Settings
  4. Scroll to and Select Reset Settings
  5. Tap Master Reset
  6. Tap Yes to confirm
  7. Enter the device's security code, then tap OK. NOTE: The default security code is 0000
Regards
LG KS660 Cell... | Answered on May 25, 2014
Take off the battery and switch it on.
LG KS660 Cell... | Answered on Apr 26, 2013
To activate the internet on your mobile you will need gprs setting from your network provider. For this you will need to contact your network service provider. They will send you some settings which you will need to save on your phone. After that you can use internet
Thanks and have a nice day
LG KS660 Cell... | Answered on Apr 17, 2013
here are various problems the lg ks660 touch screen could encounter. Although there are times when the screen does not work altogether, there are other situations when certain portions of the screen work and others don't. Press and hold the home button as well as the reset button on the top of the lg ks660 phone to turn the lg ks660 off.
LG KS660 Cell... | Answered on Jun 07, 2012
Reset the phone to company default, it will solve the problem.
LG KS660 Cell... | Answered on Feb 15, 2012
install ur phone/s pc suite to ur pc and connect ur phone
LG KS660 Cell... | Answered on Oct 31, 2011
soported LG pc swit software install on your computer then try
LG KS660 Cell... | Answered on Sep 13, 2011
Did you mean blackout or just frozen screen? Try to unlock your phone using LG KS660 unlock code then turn on your phone again. If your phone still have same problem after you insert lg unlock code do hard reset your lg phone, it will force your phone to default factory setting and if there is no hardware issue in your phone that method will works. If all of that method not works your lg phone maybe have hardware failure and you need to repair it in your local nearest mobile phone service shop.
LG KS660 Cell... | Answered on Sep 08, 2011
hello,
PUK code can be given only by your service provider which is specific for each and every mobile number.
Contact your sim customer care department over phone. Its free of cost to get the pin or puk no.
If you cant contact through your phone get some other phone and contact them.
Go to the nearest service outlet of your service provider they can also help you.
There is no other go than the above procedure only your service provider cangive
it nobody else in this world nor any software.
Go to the below link and you can confirm that the above procedure works and there is a
testimonial given by the customer too.
Take care in solving the problem.....
LG KS660 Cell... | Answered on Aug 05, 2011
Please see below instruction. Enjoy.
How to set up a new email account on the LG KS660 Viewty's built-in email client
The LG KU990 Viewty has a broadband-speed 3G/HSDPA connection which means that downloading emails on a regular basis becomes a viable option.
However it pays to check with your mobile operator's service plan to ensure that the cost of checking and downloading emails in this way does not ring up prohibitively expensive data charges. This is particularly important when you travel overseas - in such situations you should make sure that the email application is not set to check for email automatically.
This guide assumes that you have set up your LG KU990 Viewty to connect to the Internet. If you have not, check out this Internet set-up guide first.
  1. In the main menu touch the Messaging shortcut - the one with the envelope as an icon - at the bottom of the screen
  2. In the Messaging menu scroll down and click on Settings at the bottom of the list
  3. In the Settings menu click on Email
  4. In the Email menu click on Email accounts
  5. In the Email accounts menu click on the icon at the bottom left of the screen and select Add new
  6. You will need to enter all your email account information - name, email address, email servers, logon details etc. - into the online form. Remember to select the correct Access point (eg 3 Internet, Orange Internet) to ensure the email client can connect to the Internet when it needs to. Click on Save when you have filled in all the fields
  7. Your new account should be listed in the Email accounts menu. Click on the Activate button to get started...
Note: in the Email menu (Step 4) you can click onRetrieve interval and select whether you want to check and download your email at regular intervals. If you want to do this manually make sure the Offoption is selected.
Thank you for using fixya
Please rate me and give testimonials if ever to continue my assistance
LG KS660 Cell... | Answered on Jun 03, 2011
i have an LG KS660, i want to hard reset to it. do anyone know how to do the hard reset for that. I tried doing RESET SETTING, but with that the phone is not coming to its original settings. Any solution with anyone ??
My email: sfanjj@yahoo.com
LG KS660 Cell... | Answered on Apr 18, 2011
using bluetoth toggle .it is easly available in market.
LG KS660 Cell... | Answered on Mar 29, 2011
This is not due to the phone but due to the service provider.
LG KS660 Cell... | Answered on Mar 24, 2011
CHECK THE VIDEO FORMAT YOU ARE USING AND COMPARE IT WITH THE MANUAL OF YOUR PHONE.USE THE CORRECT FORMAT AND BIT RATE FOR PLAYABILITY .
IF ALL THINGS OK THEN TRY FIRMWARE UPDATE
LG KS660 Cell... | Answered on Feb 22, 2011
LG KS660 Cell Phone Logo
77 questions posted
Top LG Cell Phones Experts
George Etukudo
George Etukudo
Sheldon Dedek
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
View Most Popular
LG Cell Phones
  • LG Cell Phones
Most Popular Question
want reset all settings
  • Cell Phones
