1. Press the source button, until the radio/CD function is off and the time is displayed on the screen 2. Press and hold the FUNC (function) button. 3. A new menu will appear where you can adjust the time, warning tones etc using the arrows on the dial on the right hand side. Hope this helps, Ali
SOURCE: Pioneer eep mosfet 50wx4 super tuner 3d
the clock does not flash by pressing the (src) source button. press (scr) source button until clock appears then press the func function button (it is just under the audio button) then the clock will flash. press the up down buttons to change the hour then press the side to side buttons to switch to the minutes then press the up down button to change the minutes
SOURCE: connection to IPOD
There are many ways to do so. Each of which is progressively more expensive.
All of these plug into the Ip bus plug in the rear of the unit.
Most of these can be found on Ebay or Amazon
1: An IP bus to RCA plug then you need a RCA to 3.5mm plug wire. (note this is a lower quality) $10-$30
2: An ip bus to Ipod connect plug. (Better sound quality, charges Ipod, does not allow Ipod control from the Head unit, only from the Ipod) around $15-$30
3: An ip bus to Ipod Connectivity unit (same quality as #2 but allows for Ipod control from Head unit)
$100+
SOURCE: How can I hook up an ipod to a EEQ Mosfet 50WX4
How can I hook up an ipod to pioneer mosfet 50wx4? i cant get the aux function to show up
SOURCE: how do i connect an ipod to a pioneer mosfet 50wx4
unless you have a headphone jack or rca input in the back
i really dont know the deck but thats the 2 easy ways
SOURCE: pioneer ECQ MOSFET 50wx4 DEH-6500 Need manual
here hopes this helps ya click on the onwers manual half way down.
DEH-6500
